How to evaluate a used Volvo
This topic is in the MVS Volvo Repair Database » What should I look for in a used Volvo?
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Volvo Repair Database How to evaluate a used Volvo
Post by fazool »
--- What to look for when evaluating a used Volvo ---
People often come to MVS for advice when considering the purchase of a used Volvo:
"Is this a good deal?"
"Should I buy this car?"
"What do you think of this...?"
Essentially, everyone is asking the same question: "What should I look for in a used Volvo?"
This write-up is intended as a list of common/recurring suggestions from the MVS forums. It provides no guarantee or recommendation for any purchase decision.
Early S80: The first model-years of the S80 are notorious lemons. Stay away from early S80's (1998 through maybe 2001 or 2002).
S60 Transmission: The first years of the P2 transmissions are considered "time-bombs" for failure. Stay away from 2001 and 2002 V70/XC70/C70/S60 models.
Timing Belts: The front wheel drive Volvo's have "interference engines", which means the valves and pistons WILL collide if the timing belt breaks. Timing belts must be replaced on schedule (or earlier). Check the maintenance/service schedule. If the timing belt is overdue, or there is no record of it, have it replaced BEFORE taking ownership. Never take a used car without a record of timing belt replacement (unless its under the mileage requirement). If it's not recorded - it never happened. And if it's not recorded then this car was NOT well tended by a knowledgeable Volvo owner or mechanic. Even if the car has fewer miles than the required service interval, but is many years old, the belt needs to be replaced due to age deterioration/weakening.
Dashboard lights: Turn the key on to position II and make sure the check engine, SRS/airbag and ABS lights on the dashboard all light up. Start the engine and make sure they all go off. Unscrupulous sellers might disconnect the bulb or have a burned out bulb, hiding a deep problem.
ABS Light: Some ABS problems can be solved for a couple hundred dollars, with rebuilt ABS modules, etcetera but this is an important safety feature. If this light stays on, have this checked and repaired before buying the car.
SRS/Airbag Light: Be very cautious of SRS/Airbag fault lights. This is a major safety system and could require some serious work and should really be left to a very skilled expert or a Volvo master mechanic/dealer.
Check Engine Light ("CEL"): Most commonly, this light is due to an engine sensor or emissions control system failure. Early Volvo 850's have a user diagnostic tool under the hood for decoding a check engine light. If the vehicle has a CEL, follow the instructions in the MVS repair database to determine what is wrong. This is a simple procedure but takes patience as the process is a little slow and tedious. Newer vehicles use a standardized OBD ("On-Board-Diagnostic") connector and must be read by a "code-reader". Any auto parts chain store will read these codes for free. Some CEL codes are easy to fix and might be very inexpensive. Others could indicate some bigger underlying problems.
PCV: The Positive Crankcase Ventilation system includes several small orifices, one-way valves and screens that get clogged and gummed up. This is not a major repair but will need some work. A tell-tale sign of this is evidence of oil splashing/spraying around and on the engine. Also, remove the oil-fill dipstick with the engine running. Put your finger over the opening. A light suction is OK. Blowing or puffing out the dipstick suggests a clogged PCV system that wil need servicing/cleaning.
Transmission Fluid: Late model Volvo's have permanently sealed transmissions. Volvo recommends against flushing or draining these transmissions. Check the transmission fluid by wiping the transmission fill disptick on a white paper towel. The fluid should be a reddish brown. If the fluid is very dark or black or sludgy, you likely have a transmission problem looming. If the fluid is bright red and clear, it has been replaced and you should ask why. If you have a keen nose, you can smell the fluid for signs of burn, as well.
Engine Oil: Check the oil fill cap and oil disptick. Engine oil should be dark brown. Look for light brown peanut buttery foam or slime. This can indicate water/coolant leaking into the oil.
Turbocharger: Most Volvo's come equipped with turbochargers now. If yours has a boost gauge, watch for response during acceleration. Check from a standstill and when passing a car. The turbo boost should increase into the low teens of PSI (actual value will vary depending upon model etc.). If you don't have a boost gauge, you may want to have the boost tested by a shop. Tell-tale Volvo turbo boost should show up as an uneven acceleration - slow from a standstill but a quick snap response when passing a car, with a slight acceleration lag to the gas pedal.
All Wheel Drive: Check your AWD to make sure the prop-shaft (rear wheel driveshaft) is in place. An ad-hoc work around of a faulty AWD system is to simply remove the shaft and drive silently as a FWD-only car.
Those are some of the common reliability issues I have seen or read of. Perhaps other MVS experts can chime in and add some more.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1245 times
Post by matthew1 »
Great post, Fazool. I put it in the Volvo Repair Database.
Also -> Amazon link
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
This checklist is very systematic and easy to follow; I am printing it out and will recommend it to some people who will save time and money by just looking at it.
Thanks fazool, for all your help! :)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
Xilikon
Year and Model: 2000 V70 XC SE
Post by Xilikon »
Great text about what to watch. A better idea is to create a checklist sheet with cases to check. Like that, when you go check a used Volvo, bring that and check everything so you don't forget anything.
A word of advice would be to bring the car to a Volvo dealer or qualified mechanic for a full inspection when your preliminary inspection show no notable bad sign because some problems are well hidden that only a mechanic could find them. At least, with a checklist, you won't be paying 100$ a few times for nothing when first telltale signs of issues can be detected by a buyer.
2000 V70 XC SE with 150,000 miles, still going great !
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
10 out of 10 for Fazool.
xHeart
Post by xHeart »
I use Volvo's checklist for the up-keep of my two. This checklist is used prior to a CPO.
Is it OK to post it with this thread at MVS?
Xilikon
Post by Xilikon »
xHeart wrote:I use Volvo's checklist for the up-keep of my two. This checklist is used prior to a CPO.
I would like to get ahold of that checklist !
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Please...go for it!
'98 S70 T5
2016 Chevy Cruze Premier
xHeart
Post by xHeart »
The checklist sellers' fear. It is not a how-to, but what!
MVS_VolvoChecklist.pdf
(100.06 KiB) Downloaded 3005 times
xHeart
Post by xHeart »
fazool wrote: The first years of the P2 transmissions are considered "time-bombs" for failure. Stay away from 2001 and 2002 V70/XC70/C70/S60 models.
I frequently read your post, some multiple times since there is always more between the lines. Thanks!!!
Our 2001 V70XC is now 10+ years with 130kmi. All original, and maintained by-the-book. It is running great on premium 93, volvo/mobile 10W30 since june 2001. The timing belt was done at 123600 by the Volvo service.
Any red flags ahead - a transmission D&F this summer?
Many thanks.
