ignition coil
ignition coil
Hi i have just changed my ignition coil was as it was faulty no current coming from it.The new one is fitted and working fine but there is a very loud ticking coming from it is this normal. Thanks
poweredbyfuel
- Year and Model: 850R, 1997
I would try looking at it in the dark and see if your having an issue with your coil wire. Look around the coil and coil wire for a spark, I wouldn't stick or poke my fingers around while it's running, you'll probably the the shock of your like...
Thank you all for your help.I will try out your suggestions and keep you informed.I have looked for a spark on cables and no joy,the problem stated with the car cutting out the R A C said my coil or condenser was not working he had power going to the coil but none coming out.so i changed the coil and now a very loud ticking coming from coil/condenser.
