P102 Maf low input
meanstreak007
Year and Model: 1998
P102 Maf low input
Post by meanstreak007 »
Hello, I have a 1998 Volvo S70 non-turbo pulling OBD code P102 (MAF low input). I changed the MAF about 6 months ago so I took it back to Autozone and got another remanufactured MAF. 30 minutes later same engine code,changed air filter(paper), cleaned throttle body, looked for any air leaks couldn't find any. Then I took ground wire off and ground paint off of metal and reconnected. Cleaned new MAF again, no luck.The engine is surging at idle but over 2000 rpm is fine. Engine code comes on 5 seconds after clearing. was thinking about changing ecm, not sure if it is OK on this model. Do I just disconnect battery and replace? Thanks in advance for your help.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Did you check the line to the brake booster and the check valve?
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
meanstreak007
No not yet. Thanks, I will check that when my daughter gets home from work tonight.
Has thanked: 292 times
Been thanked: 765 times
You can't put in aftermarket MAF sensors, they almost always throw a p0102. The car will only be happy with a blue-box Volvo or Bosch (which is the same) unit.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
pkc303
Year and Model: 1995 T-5R Yellow
Been thanked: 3 times
Post by pkc303 »
Wow. I have the same code on my wife's V70. My fan stays on a few min. After shutdown too, even if the engine is cold.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
p0102 is usually a MAF problem, sometimes a vacuum leak. OP's does sound more like a vacuum problem, now that I re-read the post (stumbles at idle, but OK with high revs). But very difficult to know if there is an aftermarket MAF in there.
'06 S60 R, 197k
meanstreak007
the maf i used was a remanufactured Cordone brand from Autozone.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Well that's why. Volvos hate aftermarket sensors.
Either get a used Bosch from a junkyard, or you'll have to dish out the money for a genuine Bosch/Volvo replacement.
'98 S70 T5
2016 Chevy Cruze Premier
regent
Post by regent »
That's right - you either love your Volvo or you love your money - you can't go both ways :lol:
2015 BMW 335i
meanstreak007
brake booster vaccuum line was connected and check valve seemed to work
