volvo 850 1996 code p1310-p0304
paco0021
Year and Model: 850 1996
Post by paco0021 »
About two weeks ago I did a tune up on my volvo and I changed wires, spark plugs, rotor and distributor and they were volvo original parts. After I did that the engine was like it never it was it was working very well. and and the problem started by me driving like at 50 mph then I push the brake and I accelerated strong and the engine was shaking but I was close to my home so I quickly went home the codes I got are p1310-p0304 please help me
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
There are no codes like that
JordanW
Year and Model: 96 850R
Post by JordanW »
I believe the OP must have meant P1310 and P0304. Those would indicate a misfire in #4 (P0304) and the P1310 can be either random misfire or a #5 misfire.
I would re-check your work. Make sure the plug wires are not pinched and are secure in the dist.cap. You may also want to make sure that the rotor is secure as well as the spark shield is seated correctly.
Good Luck.
96 850R = ARD Green m4.4, rip, Kilen's, C70vert subframe, S60R exhaust manifold, NA TB with 960 plate, SNAAB J pipe, MSD coil.
paco0021
Post by paco0021 »
I already did that and everything looks good I dont know the next step ,plus the engine seems to be out of time
Has thanked: 292 times
Been thanked: 765 times
Are you sure the plug wires are attached to the proper locations on the cap? The Haynes manual is wrong about the order of the wires, if you followed that it would be incorrect.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
paco0021
Post by paco0021 »
what is strange is that it was working fine until i pushed accelerator hard
is your car a turbo or non-turbo?
'06 S60 R, 197k
paco0021
Post by paco0021 »
is turbo
Since the OEM turbo plugs are single prong, I would check the gap. Sorry if you already did that, just trying to think of things ...
If the plug wires are in the right place, and the plug are gapped to spec, then I might even try swapping plugs to see if the misfire stays in #4 or moves with that spark plug.
'06 S60 R, 197k
Pauloil
Year and Model:
Post by Pauloil »
what plugs did you put in?
99 V70XC 158K
95 850glt 188K
