ECM-990F torque monitoring faulty signal
Delirious
Year and Model: '00 S70 '03 S60
Has thanked: 3 times
Post by Delirious »
Need help please,
I checked the net for this but came up empty what is it and where is the problem component. :shock:
'00 S70SE, 287K KM
'03 S60, 168K Miles
'03 Maxima 287K KM
'06 Altima 252K KM
jimmy57
Been thanked: 320 times
Post by jimmy57 »
which vehicle which engine?
I think it is the S60 but the engine isn't specified and I would guess that it is a 2.4 non turbo.
Delirious
Post by Delirious »
jimmy57 wrote:which vehicle which engine?
S60 2.4 non turbo
'00 S70SE, 287K KM
'03 S60, 168K Miles
'03 Maxima 287K KM
'06 Altima 252K KM
jimmy57
Post by jimmy57 »
Did it have an episode of low power or run out of fuel?
That code means the torque output of engine and the throttle opening, fueling, cam timing, and ignition advance all were not in line with the crankshaft acceleration.
If the car had an episode of low power for some reason then clear the code and keep driving.
Delirious
Post by Delirious »
jimmy57 wrote:Did it have an episode of low power or run out of fuel?
Did not notice any driving issues, have not run out of fuel either but I do have another code ECM-640A (P0011). I think that is the CVVT solenoid gone bad?
'00 S70SE, 287K KM
'03 S60, 168K Miles
'03 Maxima 287K KM
'06 Altima 252K KM
jimmy57
Post by jimmy57 »
OK, that could make the torque code show up.
Delirious
Post by Delirious »
Still getting the error, and it is the only code I have. Is it a transmission ECM?
Anyone?
'00 S70SE, 287K KM
'03 S60, 168K Miles
'03 Maxima 287K KM
'06 Altima 252K KM
Delirious
Post by Delirious »
jimmy57 wrote:..............That code means the torque output of engine and the throttle opening, fueling, cam timing, and ignition advance all were not in line with the crankshaft acceleration.
Just a thought here.
Could an incorrectly installed timing belt cause this? like off a bit (there is no other fault codes)
'00 S70SE, 287K KM
'03 S60, 168K Miles
'03 Maxima 287K KM
'06 Altima 252K KM
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
yes, the 03 S60 has an exhaust CVVT gear, and if the t-belt is off one tooth it can trigger the code.
Did you recently replace the t-belt?
Delirious
Post by Delirious »
Not recently, but this code could have been there without me knowing as there is no engine light to indicate this particular issue. I will check into this when it warmes up outside.
'00 S70SE, 287K KM
'03 S60, 168K Miles
'03 Maxima 287K KM
'06 Altima 252K KM
