weirdest AC problem Topic is solved
You should be getting about 35-40 psi on the low pressure side of the AC system. It sounds like you don't have enough in it. I would doubt the compressor is bad if it is making cold air at times. I would check the switch if adding more 134a doesn't fix it.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
The switch is a pressure switch that will shut the power to the compressor off if the pressure is too low. The switch maybe next to the line port... I can'r remember off the top of my head. Other cars have them right on top of the canister or very close to it.
2004 XC70
JAZ
Do you know if it is possible that the compressor acutally doesn't pull enough voltage and stops and restarts. Seems kind of weird that it would do that. I would figure that it wouldn't work at all. never seen anthing mechanical stop and restart on voltage issues.
JAZ
Trying to find a used switch and several come up. Is the real name for the switch. is the real name Pressostat switch or is it the Map sensor that i have to change?
I have a friend here who's Dodge is doing the same thing as you described. I checked it out and it seems the pressure in the system is good but there must be a conflict between the low pressure switch and high pressure switch. It kicks the compressor on for about 2-3 seconds and then it stops without making cool air. I tend to think this is caused by a faulty high pressure switch. I will do some more research on the Volvo.
2004 XC70
JAZ
Well it seems that maybe that duracool stuff i was bragging about isn't so good after all. It might cause pressure problems thus making the AC switches shutoff the system. Might try to pick up a used cut off switch and give a try but sounds like a complete flush and refill of 134a.
regardless
There might be a chance the the Linear Map sensor is worn Volvo part number 8628563. If a 134A charge increased the cycle time for the compressor and the ac quit after rpm above 3000 the map sensor is a good canidate for inspection. Located on the high side AC line Pass side just behide the rad core support. It has a 3 wire connector and sends a resistance value to the ECC for the high pressure circuit of the AC system. When they become worn the resistance increases. That signal gives the ECC an incorrect high pressure and opens the compressor clutch circuit.
JAZ
Well, decided to take it in for a flush and a fresh 134a refill. Guess what? Flush worked great but the mechanic wasn't able to refill it. It just wouldn't take in the gas. He thinks that maybe there was too much duracool in it and the evaporator might a froze while i was driving down. Going to wait a few days to let it warm out and going to try to refill it.
- 1338 Views
- 12 Replies
- 3041 Views
Last post by Jaguar xjs
