1990 Volvo 740 GL will not start
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Rafael
Year and Model: 740 GL 1990
Post by Rafael »
Dear gentlemen,
I have a 1990 Volvo 740 GL, VIN # YV1FA8845L2412205 that in good shape but lately
I have been experiencing some problems related with fuel flow.
Unfortunately here in Venezuela we don´t have much experience with Volvo and there
Are no mechanics that know what they are doing.
I need to purchase some parts, no doubt, but first I would need to double check what I have
With how the car should be.
I need some detailed pictures of the engine in several views and close ups and most of all
Of the fuel system in its entirety so that I can make sure that everything is where it should be
And then check each individual part and purchase the faulty ones.
I plan to do this myself because I like said there are no mechanics that know what they are doing.
I think that I have a fuel problem because the car starts ok but dies out immediately. I have checked
The fuel Fuel Injection Pressure Regulator, I have changed the Regina Idle Air Control (IAC) Valve, the
Throttle Position Sensor (TPS), the Regina Manifold Pressure (MAP) Sensor and still I have ignition
Problems.
Last year I changed the fuel pump using a Chevrolet Cavalier 2000 pump and worked just fine. Yesterday
I changed it again because I was told that the pressure was too low and bought another one exactly
The same and still I have problems turning on the engine.
I also changed the original Volvo spark plugs with brand new Bosch spark plugs and nothing.
I of course have also changed the fuel filter, engine oil , air filter and oil filter.
One last thing, when I spray S&Q carburator into the air intakehose, the car starts just fine and
sounds really powerful BUT as soon as I stop spraying the engone sputters and dies out.
I really don´t know what to do because I am not a mechanic and I love my car.
Can you help? Please? Thank you very much.
Regards,
Rafael Volpe
+58-412-622-4543
JDS60R
Been thanked: 3 times
Post by JDS60R »
Hi Rafael,
Could you please hook up a fuel pressure gauge to the fuel rail, Then hook up a meter to the positive side of the coil and a test light to the negative side of the coil.
I would like to see if you are losing fuel pressure, coil voltage or coil signal after the car starts. many time this can be as simple as the fuel pump relay failing.
I will process your request for the fuel system overview next. I can not decode your vin so I will assume it is a non turbo motor.
Retired
JDS60R
Post by JDS60R »
Ok, there are many non turbo motors and fuel systems. I will need to know your motor code
Retired
JDS60R
Post by JDS60R »
Ok - I got your vin decoded and see you have an 88 in the vin which equals a B230F
Fuel system coming up
See attachment for clearer Vin decoder
Volvo 1990 Version Identification Number (VIN) Decoding
VIN number breakdown
YV1 A X 45 4 X L 1 000000
Manufacturer's code = = = = = = = = = = = = = = = = = = = = = = = + | | | | | | | |
Assigned by ISO | | | | | | | |
Series = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = + | | | | | | |
A = 240 Sedan & Wagon, F = 740 Sedan & Wagon | | | | | | |
G = 760 Sedan & Wagon, H = 780 Coupe | | | | | | |
Safety system = = = = = = = = = = = = = = = = = = = = = = = = = = = = = + | | | | | |
X = 3-point seat belt security system | | | | | |
A = 3-point seat belt & drivers' side airbag | | | | | |
Engine = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = + | | | | |
69 = B280F, 87 = B230F-Turbo, 88 = B230F, 89 = B234F | | | | |
Body = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = + | | | |
2 = 2 doors, 4 = 4 doors | | | |
5 = 5 doors | | | |
Check figure = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = + | | |
Calculated from other digits | | |
Year model code = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = + | |
A = 1980, B = 1981, C = 1982, D = 1983, E = 1984, F = 1985 | |
G = 1986, H = 1987, J = 1988, K = 1989, L = 1990 | |
Manufacturing plant = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = + |
0 = Kalmar, Sweden, 1 = Torslanda, Sweden |
2 = Ghent, Belgium, 3 = Halifax, Canada |
A = Uddevalla, Sweden, D = Turin, Italy |
Chassis number = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = +
For 1990 year models, the serial numbers start at:
240 4 door ... 386700 , 240 5 door ... 846100
740 4 door ... ??????, 740 5 door ... ??????
760 4 door ... ??????, 760 5 door ... ??????
780 ... ??????
vin1990.pdf
(189.45 KiB) Downloaded 386 times
Retired
JDS60R
Post by JDS60R »
Here is the fuel system - I only have a parts diagram.
Let us know what you found out about fuel pressure and coil voltage and signal.
If you only have a test light - start with the coil
Place positive to positive an ground to ground - you should see the pulses of the coil.
If coil is ok
Put test light on fuel pump 1 at a time if you have 2 - see if you are getting voltage/amperage to the pumps. One of them is giving out on you .
When the car dies - if it stutters and stops then suspect fuel first. If it runs and then dies like someone turned off the key - suspect ignition and related pulse sensors (crank sensor etc)
740 fuel.pdf
(211.47 KiB) Downloaded 653 times
Retired
JDS60R
Post by JDS60R »
here is your owners manual to help with fuses etc.
740_1990.pdf
(2.71 MiB) Downloaded 731 times
Retired
JDS60R
Post by JDS60R »
Pics of relays to check
1990 relays.jpg (36.92 KiB) Viewed 5747 times
1991 relays.jpg (99.72 KiB) Viewed 5747 times
relay pic.gif (15.38 KiB) Viewed 4692 times
740 relays.gif (21.51 KiB) Viewed 4692 times
Retired
Rafael
Post by Rafael »
The VIN is the following: Y = Sweden, V= Volvo, F=740, A=3 points seat belts, 88=2.3l, 4 cyl, B230F
4=50 states, 5=internal number, L=1990, 2=Belgium, 412205=Serial.
My Volvo is not Turbo.
It has a Regina fuel system.
Can you please tell me what is a "coil" and where is it? Tomorrow the mechanic is coming and I will share all of this info with him.
When you wrote "Put test light on fuel pump 1 at a time if you have 2 - see if you are getting voltage/amperage to the pumps. One of them is giving out on you ". My car only has one. Should I put the test light with the key in the start position? Should I crank the engine? Or simply put the test light with the engine off.
I will let you know tomorrow of the outcome.
JDS60R
Post by JDS60R »
By coil - I meant ignition coil ( device that makes the sparks)
Test the ignition coil and the fuel pump while the car is running. When the car starts you have both ignition and fuel working . When it is stalling you are losing at least the spark or the the fuel (needs both to run. By monitoring both you will see which one is failing on you.
Retired
JDS60R
Post by JDS60R »
picture of ignition coils for 740
740 coil igntion types.jpg (309.45 KiB) Viewed 5738 times
Retired
