Power Steering Groaning Ever So Slightly
geokilla
Year and Model: S70, 2000
Post by geokilla »
My power steering is groaning ever so slightly. I had the power steering topped off today at the dealer, which I was hoping would fix the problem, but I guess it didn't as I heard it groan just as I turned into my driveway. What could be the cause of the groaning? I'm thinking that I might need to apply some grease as I didn't apply any grease since changing the control arms last month.
2000 Volvo S70 SE; First Owner; 321km; Retired
2012 Volvo S60 T5 Level II; Gone
VolvoTurbo850
Year and Model: 1994 850 (T5)
Post by VolvoTurbo850 »
do you mean it is always groaning or just when you make a hard turn?
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
And is it the pump noise or more of a squeaking noise like a bushing or something?
'98 S70 T5
2016 Chevy Cruze Premier
geokilla
Post by geokilla »
Hard turn as in full lock or close? No. It just groans whenever.... It doesn't happen all the time. It actually happens very rarely.
If I remember correctly, it's not a squeaking sound. It's like a "uuugggghhhh" kinda sound? But it's really short.
VolvoTurbo850
When you make a hard turn and older system is going to protest with a groan. How dirty is the oil in the steering pump? Sometimes just cleaning that out will help. Otherwise one of those things you should just live with unless it is happening all the time.
I find it odd that your dealer didn't comment on it when they topped it off.. unless they could not hear it either.
The Fleet
2001 V70 (NA) 2.5
1994 850 Turbo (T5)
geokilla
Post by geokilla »
So they wanted to take apart my steering today to see if this spring was broken in the steering column, since my signal stalk does not return after making a turn. Was gonna get charged $100.... Should I be worried, in terms of safety? Been groaning for so long now I just ignored it.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
If it is not groaning at other times it just may be an alignment especially when it is just when turning. Check tire wear.
Take a Turkey Baster and remove all the Fluid in the reservoir and refill. Turn on Vehicle for 20 seconds and turn steering wheel one turn each side while the car in running. Remove and refill 3 to 4 times total and drive to see if it improves.
This is what I use for PW ST Fluid (20W). Never had a power steering problem with all my cars except for a Celica which was leaking when I got it.
http://www.pelicanparts.com/catalog/sho ... o_pg10.htm
coldax
Year and Model:
Post by coldax »
Is the fluid foaming in the reservoir? Mine was groaning and foaming. So I turkey-basted out all the fluid and replaced the two hose clamps that lead into the reservoir due to small air leaks (causing the foaming). I used a couple of .25 cent band clamps.
Groaning and foaming has stopped.
2015.5 V60 T5 AWD Platinum
2012 XC60 T6
2012 S60 T6
2011 S40 T5
Gone but not forgotten:
2009 C30 R Design Sold to buy more Volvos
2007 S40 2.4 t-boned and totaled :evil:
2010 V50 2.4 hit a deer and totaled :(
2000 V70 SE head gasket :cry:
2000 S70 SE sold with 240,000
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Are you sure it's not the lower steering column bushing?
They do go bad
Pull up the carpet, get some grease on it.
If that works, you can replace it later on at your convenience
jblackburn
'98 S70 T5
