Great work, Susan.
A few years ago I thought I would have to replace mine, because it was squeaking like a nest of birds in right-hand turns (or was it left?). I pulled it and decided to try lubing the motor. Drove out the motor from the plastic fan cage and oiled the bearings, or tried to. Lasted only 6mo or so before the return of the birds. Pulled it again, and this time I noticed that the bearings are protected by flexible plastic/rubber dust shields. I pried them up a bit to get oil under them. 40K miles later, the birds are still at bay. Anyway, maybe worth a try before plunking for a new one if it's a matter of squeaks.
Climate unit blower replacement
dahammer
- Year and Model: 2005 S60 2.5T
Thanks Lee for this write up, I picked up a used blower fan at a junkyard (along with a driver's door and clock spring for my daughter's 1997 Hyundai Tiburon). It worked like a charm. I still have the flashing lights though.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Over the years on my '97 855 GLT I've removed the cabin HVAC blower motor a couple times to apply grease to the bearings, generally when I started hearing the squeaking sound from the blower. The last time I heard the squeak was about 2-3 years ago when turning the car to the right. I removed it and greased it again, and all was well until a couple of weeks ago, when I started to get the flashing AC / REC lights on the ECC module, always at start up. I did not hear any squeaking but I guessed that the blower motor bearings were seizing up again. I decided to replace the blower this time instead of just greasing the bearings again.
I found a used blower unit on eBay that had already been opened up and had a new Bosch motor installed. The price ($85) was just a bit higher than the cost of the new motor alone from FCP ($63 Bosch part #0130111134).
After I got the old blower out, I measured it's current draw compared to the new blower. The load line graph below shows a slightly higher current draw on the old blower (red points) compared to the new one (blue points) of about 0.4 Amps at 8V.
I could not test the blowers at higher currents because my supply and meters were limited to 10A. In fact, the first current meter I used -- a Harbor Freight cheapie that I got with a "FREE" coupon -- blew out at about 6A despite being rated for 10A. I opened that one up and took a look at what failed: After the smoke cleared, I used a different, higher quality multimeter to get the data in the load line graph above. While testing, I could hear faint squeaking coming from the old blower (I hadn't heard this while it was in the car, either because it's harder to detect while it's installed in the car or because the blower developed the squeak again during removal or testing).
I installed the new blower in the car and have been testing it out in the car for a couple of weeks. So far, no blinking AC / Recirculation lights and all is well.
I then disassembled the old blower by removing the cage, electrical connector, screw and case. Down the road when the bearings in the new motor start squeaking, I'll remove it and grease the bearings and I'll have a spare cage and case available in case anything breaks.
Just took out my fan today to fix the "squeaking" issue. Blew it out with air and applied some PB Blaster to the bearings and the thing works like a charm and is really quiet now.
Only issue is that now my car smells like PB Blaster... Any ideas how to fix that?
1993 Volvo 850 (w/97' engine in it)
- Year and Model: Many Volvos
- Been thanked: 76 times
alexk243 wrote:Only issue is that now my car smells like PB Blaster... Any ideas how to fix that?
Time and perhaps some of that "new car smell" stuff that they sell. I had used the back of the XC to store all of the parts I pulled off the old engine and it sat that way for months while I looked for a new engine. It smelled pretty bad but my wife took it in for a detailing and whatever they sprayed made it smell nice again.
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
Are you kidding me? I WISH my car smelled like PB! It's like crack in "garage form"!alexk243 wrote:Only issue is that now my car smells like PB Blaster... Any ideas how to fix that?
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
camjohns
- Year and Model: N/A 850 97, 850R 96
- Has thanked: 6 times
Not sure the difference between ecc and mcc? I have a 1997 850 with the squeaking motor, as well i do not have blower speeds 1-3. Not sure what i need to replace other than the blower motor? thoughts?
thanks
thanks
vjaneczko
MCC is Mechanical, ECC is Electronic. The big clue is the speed indicator, which you have, indicates you have MCC. The ECC has a variable speed slider for the fan.
Many times what will happen is the fan will get clogged up or worn out and increase the resistance during spin. This in turn creates heat and the system will begin to fail. What also happens is that the additional resistance will cause the blower resister to fail. It’s common to have to replace both devices at the same time.
Another thing to check is to see if you have an air filter installed – some do, some don’t. This goes under the wiper cover accessed from under the hood. If you have one, it’s probably fallen apart. If you don’t have one, you’ll need to also get a filter bracket which snaps into place and hold the fan in place.
2006 S60R - For ME!
2006 S60R - For ME!
- 1322 Views
Last post by Jepc
- 2422 Views
Last post by DrDan
- 2115 Views
Last post by Jumbobazman
- 2513 Views
Last post by nsomlai
- 1131 Views
