$3,900 – Toronto Area
One of only a handful of 1996 Turbo wagons with a manual transmission imported into Canada.
I purchased this car from the original owner about 3years ago and I was one of 8 guys after it. I got it because the owner thought that I would give it a good home.
I am selling it only because I have been offered a great deal on another wagon.
It is red with a black leather interior. The paint is in good condition with regular polishing and waxing. I have used a grey dye from IPD to rejuvenate the trim.
The mileage is about 321, 000 kilometres (200,000 miles) but is a good daily driver.
Notes, Equipment and Service
• Second owner
• Original condition
• Never smoked in
• Everything works
• Original owner serviced it at Volvo dealer
• I have had it serviced at APPCO “the Volvo Doctor” exclusively
• Oil changed regularly with OEM filter and Castrol GTX
• I always used premium grade fuel
• 4 summer tires – mounted on Columba alloy wheels
• Sunroof
• Rear cargo mat
• 2 sets summer floor mats
• 6 CD player
• IPD – intermittent wiper control
• Updated Volvo radio – cassette player with IPOD pickup
• Leather in excellent condition – no splits
• Mileage – urban 10L/100km; highway 8.5L/100 km
• Clean Car Fax when I bought it, no accidents on my watch
Available for extra $500
• 2 sets winter floor mats
• 1 set of summer floor mats
• OEM roof racks and 2 bike holders and ski racks
• 4 winter tires – mounted on Cetus alloy wheels
The Good
Previous Owner
Kilometers Item
60,000 Main Engine Seal replaced under warranty
60,000 Clutch Replaced
186,942 oil, filter, new aux. belts,
192,000 Service; oil, filter, fuel filter, brake fluid, spark plugs, dust filter, recharge AC
205,199 New AC evaporator, recharge AC, replace dash bulbs, oil and filter
205,926 Rear shock mounts, gas tank inspection
218,564 New radiator, ABS controller
231,000 Rear Brakes
Current owner
Kilometers Item
231,722 Fuel filter, cabin filter, left and right stabilizer links, right control arm, left wiper arm, timing belt, auxiliary belt, idler, OEM exhaust tip
243,831 Right upper strut mount and spring seat, thermostat, air filter, distributor cap and rotor, spark plugs
264,552 Left front CV drive shaft, rear brake pads left front wheel bearing
279,290 Front brake rotors, pads and calipers, brake flex lines, Right front CV axle
298,911 Starter motor
301895 Coolant reservoir, cap, cabin filter
302,552 Water pump, coolant reservoir hose
312,894 Oil cooler lines, oil return tube gasket and seal, handbrake shoes
316,287 Heater blower motor
317,295 Rear wiper transmission, wiper blade, hatch clips
319,000 Odometer gear, dash lights replaced, replaced radio, seat skin replacement
320, 171 Fuel pump
The Bad
-AC runs cold for about 15 minutes
-door dings (previous owner)
-stone chips
1996 Volvo 850 Turbo Wagon with Factory 5 Speed
gtamike
- Year and Model: 855 Turbo, 1996
- 3560036787_415c4879d6_z.jpg (179.46 KiB) Viewed 3786 times
- 4719198571_93a8b70b74_z.jpg (168.4 KiB) Viewed 3786 times
- 32083990050_medium.jpg (9.4 KiB) Viewed 3784 times
- 32083990019_medium.jpg (12.08 KiB) Viewed 3784 times
"Long may you run"
Current
- '96 855 Turbo 5 spd - 242,000 kms - working to get to Stage 0
Previously
- 1996 855 GLE 5 spd. 450,0000 kms, sold & still alive
- 1989 745 GL - 5 speed
- 1987 765 - autobox
- 1971 145S - swan neck 4 speed
Current
Previously
gtamike
Contact - [email protected]
"Long may you run"
Current
Previously
Current
Previously
gtamike
Still for sale
Price reduced to $3500
New Battery
New Battery
"Long may you run"
Current
Previously
Current
Previously
gtamike
SOLD
"Long may you run"
Current
Previously
Current
Previously
