windshield wipers
windshield wipers
hey just ran into a problem with my 1992 960. the windshield wipers wont turn off unless i pull the fuse. anyone have any advice?
fazool
- Year and Model: S60, 2007
- Been thanked: 7 times
Probably only one of two things causing it:
The switch itself is broken. This is likely because its the part thats always moving.
The other could be a relay that is broken in the ON position but that is unlikely but easier to test/check.
If it was me, I would pull the wiring diagram, find if there are anyt relays for this and which they are. Then I would pull the relays and test them with a simple meter to check for function. I would remove/install them and see what happens. If I can convince myself the relays are fine, I would pull out the stalk and replace it with a junkyard stalk.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
