poor gas mileage, no power uphill.
gondwana
Year and Model: 1998 V70 T5
Post by gondwana »
The car is a 98 v70 t5 with 185,000 miles. I have no check engine light on. No stored codes. I was thinking that is the CC is going out or plugged. I can't get passed 65-70 mph's on freeway. O2 sensor's are original never changed. What would be the best way to attack this? Looking for the least expensive way.
Thank you
Recently replaced
full tune up
oil change
fuel filter
air mass meter
air filter
pcv kit
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
If you suspect the catalytic converter let the car cool off and then bang on the converter with your hand. A bad converter will sound like it is full of gravel.
Normally you would get a check engine light with a bad converter with a range limit code on Bank 1 Sensor 2.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Are you sure there are no air hoses loose?
Check ALL intercooler hoses - especially the one at the bottom of the intercooler. I've had one blow off slightly without throwing a code before, but it was dumping out most of the air before it reached the engine.
'98 S70 T5
2016 Chevy Cruze Premier
gondwana
Post by gondwana »
When replacing o2 sensors do i need to replace both front and rear?
madspeed50
Year and Model: 1998 S70 T5m
Post by madspeed50 »
Do you have a boost gauge? What is the turbo doung? Is it working hard but not getting you anywhere? Or is it the problem?
Yep, sent from my rooted, rommed Galaxy Nexus....
madspeed50
I had a MR 2 turbo that did this when the turbo took a dump
Been thanked: 472 times
Post by cn90 »
To diagnose a clogged catalytic converter, it is very easy.
With car in Park, ask some one to rev up and down the gas pedal while you stand at the tail pipe with a piece of paper right at the end of the tail pipe, the paper should "fly" when the rpm goes up, if not, the cat is clogged!
gondwana
Post by gondwana »
Ok replaced front 02 sensor but, both front and rear sensor's are very close to each other the CAT is original from factory.
Should i replace the second one also? I thought the rear sensor was after the CAT? There is some performance gain and better mileage.
madspeed50
pull out the rear o2 sensor and clean the soot off it
