n/a cam swap question
trophytaker308
- Year and Model: 1995 850t turbo
will this be a noticable uprgade if i put n/a cams in my 95 85 volvo((((TURBO)))) t-5,will there be a noticable difference in doing this mod,low end and top end???..thanks for any help.
1995 850t turbo,siver with black leahter interior (perfect),, 118000 miles .second owner.9 out of a 10...!
trophytaker308
no one knows about this....???
- Has thanked: 2861 times
- Been thanked: 1332 times
Search knows.
From my Cam timing resource post:
- Advancing/retarding timing on Volvo inline-5 engines for performance
- Setting cam timing after timing belt job
- Performance cam timing adjustment didn't help hp... an account by a trusted Volvo tech
- More Cam timing tips with photos
- Quick Brick Cam Timing Tool documentation added 2/2011
trophytaker308
well i did look in the search and didnt find what i was looking for...ohwell.no biggie..thanks.
No problem, let us know how it goes, what you do with the cam timing.
trophytaker308
i might??? but like i said. i have found now were on here how much better n/a cams are on a turbo car..i know how to adjust the cams..u must of misunderstood what i was talking about...???
trophytaker308
and the info posted didnt direct me to the thread eighter,and the topic i was perfering to...go figure...lol
You're correct, I didn't understand that you're transplanting an NA cam into your turbo. I read too quickly and thought you were adjusting your timing and nothing more. Sorry for the chasing-your-tail information I posted.
- RobTheModd
- Year and Model: 98 S70T5M
- Has thanked: 5 times
- Been thanked: 7 times
Good day.
The n/a cams are said to be good for about 10-15hp gain depending on your set up.
We recently swapped them over to my car, and re-adjusted the timing as per the specs on ARD's website.
I am also running a blue tune in my car and am very pleased with its performance.
The N/a cams are a great upgrade for the T5 or Turbo models.
You can pull the cams from any non turbo 850 93-97 and 98 70.
The 93 cams are said to be the best of the n/a cams.
trophytaker308
so how is the blue tune working out for you,and what size turbo did u go with.???have u done a dyno on it yet?
- 1503 Views
Last post by iRenaissanceMan
- 19 Replies
- 5519 Views
- 2065 Views
Last post by wizechatmgr
- 23 Replies
- 2597 Views
- 877 Views
Last post by THannah696
