2002 S60 coil replacement - can do?
vooman
Year and Model: s60, 2002
Post by vooman »
My 2002 s60 was running fine, until the other day. At idle it was running real rough, like a cylinder was out of commission, above 35 it smoothed out. The message panel was advising to shift up or shift down, and the check engine light was blinking.
I take it into a Volvo garage, he hooks it up to vadis and tells me a coil is dead, and other will probably fail soon. He'll fix the one for $180. But he's swamped and can't take it in today.
We're moving so $$$ is a bit tight. A quick search shows that a Bosch coil runs about $55 - I assume that's the part. Is this something I can do myself? Since I'm between homes all my tools are in storage - are any special tools needed? Can I just tell which coil is dead by pulling spark wires, or..? I've never worked on fuel injection ignition systems before, so I'm a bit new to this. But if I can save $100 that would be great.
Thanks for any assist.
fn42
Year and Model: 98 V70, 00 S80
Post by fn42 »
https://www.matthewsvolvosite.com/forums ... =9&t=27232
This guy did the spark plug too, imo this is optional but might be a good idea
You will need to take it to autozone or something to have someone read the DTC, this is how you'll figure out which coil needs replacement. Cylinder 1 is the one all the way on the right side of the engine (left if you are standing in front of the car facing it) FYI
asc325is
Year and Model: s60 2.4t 2002
Post by asc325is »
super easy to do. just take it one step at a time and don't drop anything
vooman
Post by vooman »
Looks like I'll need to buy a few tools I already have, but can't access. Oh well, that's what Harbor Freight is for!
Thanks!
