1996 850 Want to add remote entry.
How to integrate your phone into your Volvo's audio. Which speakers to buy to replace old ones. Recommended head unit brands and models... This is where we talk watts, ohms, GPS, iPod integration, component installation, tips, tricks and advice for making your Volvo's audio, video, ticket avoiding and mapping gadgets work better than ever... iPod, XM, GPS, DVD, Speakers, Amps, Radar Detectors
Mark1996
Year and Model: 850, 1996
Post by Mark1996 »
I recently purchased a 1996 Volvo 850. It is a standard non-turbo car. It did not come with remote keyless entry. I took out the glove box, found the green connector where the remote unit would connect. Later i bought one off of ebay (part# 9148645). I then purchased 1 used Volvo 850 remote and 1 aftermarket remote (both are supposed to work with this). I tried the programming of this (turn ignition off and on 5 times in a 10 second period, then press remote lock or unlock). Do I need anything else??? I am thinking their might be another set of relays that should be installed here. Any ideas would be greatly appreciated. Thanks.
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
1) Are you sure you got the right Volvo remote - check the FCC ID numbers.
2) I think you need the 210/211 relay. Since you've gone this far, you might as well add the dash LED and alarm horn as well.
5 others that came and went
