Key Fob V70
xyz
Year and Model: V70 T5 2005
Key Fob V70
Post by xyz »
I have an old, epoxy resined together remote key fob. Right old mess. Sawed and cut it apart.
Bought new empty key fob case from Ebay and transferred bits from the old one to this new bit of stuff.
Worked on unlocking and locking doors, but wouldn't start the engine.
Found out that there is a little immobiliser chip fitted into the top plastic part which holds the blade.
Frightened to gouge it out of the old wrecked fob, so hold it close to the key when starting; and hey presto, the engine starts.
However, I would like to get the little bugger (sorry, Chip;) out of the old and into the new fob without damaging it.
Does anyone know how delicate these little ****** are. If I lever it out with a screwdriver, could it be damaged, then cost me an aweful amount of dosh to fix it.
packetfire
Year and Model: 2010 v50 2.4i
Has thanked: 17 times
Been thanked: 30 times
Post by packetfire »
Might I suggest that you cut with care AROUND the chip, and then glue the plastic hunk with the chip imbedded in it to the inside of the new casing you bought? Keep away from where the battery goes, as you don't want to prevent battery installation, but up near the screw that holds the case together?
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
xyz
Post by xyz »
Thanks for that Packetfire.
xyz
Post by xyz »
packetfire wrote:Might I suggest that you cut with care AROUND the chip, and then glue the plastic hunk with the chip imbedded in it to the inside of the new casing you bought? Keep away from where the battery goes, as you don't want to prevent battery installation, but up near the screw that holds the case together?
I started off as you suggested; junior hacksaw close to one side of the chip. Then filed away the plastic until very close to the glass chip.
From there, when I saw it was glass, I used a sharp stanley knife to shave off paper thin slices until the chip was released, intact. Was I chuffed.?
Of course, now I had a clean chip, it went in it's correct position to the side of the base of the blade.
It took around 3 hours! but saved a stack of dosh.
I rang the local Volvo dealer and informed them that they were wrong; the chip is not in the metal blade. Next time I visited them, they were all over me asking how I found that out, as they always thought it was inside the metal. Ha Ha!
Thanks again for your help. :)
vjaneczko
Year and Model: 2006 S60R
Been thanked: 6 times
Post by vjaneczko »
DIY's are always fun but even better when you get to teach the dealer a thing or two!
1997 855 GLT - R.I.P.
2006 S60R - For ME!
