Does anyone have any feedback on its long term use. Would like to know if there were any driveability issues or thought there may have been a flow restriction causing the fluid to get dirty or burnt prematurely. I have 2 sitting around from 10+ years ago that I never installed. Had installed 2 TransCoolers and did not want another splice in the system.
Mangefine Filter Installed w/ Pictures
Mangefine Filter Installation Tutorial w/ Pictures
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Tonyx
- Year and Model: 2001 XC70
- Has thanked: 3 times
- Been thanked: 8 times
Installing magnefine filter in on my to-do list.
However just wanted to clear up a misunderstanding about the AW transmission in our cars. It does have trans oil filter and it's a robust design. However it's buried deep inside and need to split the case to get to it. This info is from former AW transmission engineer.
2003 XC70 230K and counting..,
Tonyx
Has anyone cut used Magnefine filter open to see how effective it was?BKM98 S70 T5 wrote:-
Howard_Woodard
- Year and Model: 2009 XC90 V8 AWD
Thanks!
Howard Woodard
Redmond, WA 98053
2002 Volvo V70 XC AWD w/2.4L Turbo (Chassis #058794)
Redmond, WA 98053
Tonyx
There is a filter built into the trans itself, but it's only accessible by opening up the case. Magfine is incremental filtering.
Do you have any experience to share pros/cons?
- 1560 Views
Last post by 93Regina
- 15 Replies
- 2927 Views
Last post by 454cid
- 2033 Views
- 722 Views
Last post by davidlevine08
- 28 Replies
- 8623 Views
