Defeating the torque limit request on the Volvo 850 Turbo
This topic is in the MVS Volvo Repair Database » Defeating the torque limit request on the Volvo 850 Turbo - TCM Signals
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
The torque limit signal isn't a concern for rods. The engine will not readily go to full boost so quickly in lower gears as the engine speed builds more quickly with lower load of the lower gears. It does increase stress on transmission. The reason is the too easy wheel spin and the much worse torque steer. THe TCV and its function to keep torque output steady over wide engine speed range is a solution the treacherousness of explosive torque output and the tugging of the steering wheel it causes, especially on irregular pavement.
I located the wire at pin 1 of TCM, it is a short wire that goes next door to the base of ECM. I cut it and spliced a piece of 18 ga. speaker and ran that into car via the port provided by volvo. The cruise hose, and on some cars some wiring, is run through that corrugated conduit you will find at left strut tower. IT will have some nipples that are not cut on it for you to cut and use. There is no fault code for interrupting it as it is signal that gets grounded by TCM. When not grounded it will be at full 5V value like it is when TCM is not grounding it. Running it to switch on dash allows you control of the extra OOMPH you'll get.
IF only there was such a simple way on networked cars...........................
kcjones
Year and Model: 1997 855 GLT 200k :)
Post by kcjones »
Hmm..........I am getting ready for a set of winter tires....... :twisted:
boosted5cyl
Post by boosted5cyl »
I'm totally doing this and making it a red button.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
boosted5cyl wrote:I'm totally doing this and making it a red button.
:-D
Or
This 12v switch on Amazon.com w/MVS link embedded. More practical than a button, because you'll need both hands fighting that torque steer.
Also -> Amazon link
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
matthew1 wrote: Image
OMG that is so cool I think I'll replace every switch I come across - and that includes my light switches at home! :lol:
1997 855 GLT - R.I.P.
2006 S60R - For ME!
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
"Whatever you do, don't hit the red button!"
Hmmmmmm...
*hits button*
*SCREEEEEEEEEEECH*
:D
'98 S70 T5
2016 Chevy Cruze Premier
matthew1
Site Admin
Post by matthew1 »
Image taken from Canonnball Run, Mitsubishi Team car interior. The car is actually a Subaru GL, and Jackie Chan is Chinese, but hey, it was 1981 :roll:.
Also -> Amazon link
c70_lindsay
Year and Model: 99 S70 T5.
Post by c70_lindsay »
Can this be done on a 2000 C70 Hpt?????
jimmy57
Post by jimmy57 »
c70_lindsay wrote:Can this be done on a 2000 C70 Hpt?????
NO, it uses network communication and the torque reduction is in a data stream you can't interrupt.
1998 is the last year.
hanzbe420
Year and Model: 2006 s60 2.5T
Post by hanzbe420 »
Will this work on a 94 Volvo turbo wagon. 2.3l with obd1 and obdII. And if so can some one post a picture of the wire, so i no were to wire the switch exactly to? Plus it will be useful for future members! Thank you! :D
