The torque limit signal isn't a concern for rods. The engine will not readily go to full boost so quickly in lower gears as the engine speed builds more quickly with lower load of the lower gears. It does increase stress on transmission. The reason is the too easy wheel spin and the much worse torque steer. THe TCV and its function to keep torque output steady over wide engine speed range is a solution the treacherousness of explosive torque output and the tugging of the steering wheel it causes, especially on irregular pavement.
I located the wire at pin 1 of TCM, it is a short wire that goes next door to the base of ECM. I cut it and spliced a piece of 18 ga. speaker and ran that into car via the port provided by volvo. The cruise hose, and on some cars some wiring, is run through that corrugated conduit you will find at left strut tower. IT will have some nipples that are not cut on it for you to cut and use. There is no fault code for interrupting it as it is signal that gets grounded by TCM. When not grounded it will be at full 5V value like it is when TCM is not grounding it. Running it to switch on dash allows you control of the extra OOMPH you'll get.
IF only there was such a simple way on networked cars...........................
Defeating the torque limit request on the Volvo 850 Turbo
Defeating the torque limit request on the Volvo 850 Turbo - TCM Signals
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
I'm totally doing this and making it a red button.
- Has thanked: 2861 times
- Been thanked: 1332 times
boosted5cyl wrote:I'm totally doing this and making it a red button.
Or
This 12v switch on Amazon.com w/MVS link embedded. More practical than a button, because you'll need both hands fighting that torque steer.
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
OMG that is so cool I think I'll replace every switch I come across - and that includes my light switches at home!matthew1 wrote:![]()
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
"Whatever you do, don't hit the red button!"
Hmmmmmm...
*hits button*
*SCREEEEEEEEEEECH*
Hmmmmmm...
*hits button*
*SCREEEEEEEEEEECH*
'98 S70 T5
2016 Chevy Cruze Premier
Image taken from Canonnball Run, Mitsubishi Team car interior. The car is actually a Subaru GL, and Jackie Chan is Chinese, but hey, it was 1981
c70_lindsay
- Year and Model: 99 S70 T5.
Can this be done on a 2000 C70 Hpt?????
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
c70_lindsay wrote:Can this be done on a 2000 C70 Hpt?????
NO, it uses network communication and the torque reduction is in a data stream you can't interrupt.
1998 is the last year.
- hanzbe420
- Year and Model: 2006 s60 2.5T
Will this work on a 94 Volvo turbo wagon. 2.3l with obd1 and obdII. And if so can some one post a picture of the wire, so i no were to wire the switch exactly to? Plus it will be useful for future members! Thank you!
- 2393 Views
Last post by waffleshill
- 3968 Views
Last post by Integrexman
- 3976 Views
Last post by goldmandan
- 18 Replies
- 9793 Views
Last post by Orchid70
- 1120 Views
Last post by cn90
