89 740 auto od issues
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
wadeo611
Year and Model:
Post by wadeo611 »
I have an 89 740 automatic wagon that lost od. Replaced solenoid and cleaned relay. i do have actuation of the solenoid. Is there any other inhibit of engagement of od ? The old solenoid was definatly shot. Help !!!!! This moms car.
Thanks, Wade
89 740 210 k ( moms )
97 850 505 k (mine )
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
I am assuming you can hear the solenoid activating when it is attached to the gearbox. If that is the case there may be dirt in the oil-way to the solenoid which will stop the fluid passing through. One way to check the oil flow and clean out any possible dirt is to remove the solenoid, place a tray under the transmission, start the car and quickly shift the gear lever from P to 1 and back to P then quickly switch off the engine. This should only take a few seconds and should result in a flow of oil which should clear any blockages.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
