How to test and repair your EVAP valve:
This topic is in the MVS Volvo Repair Database » How to Test and Repair your EVAP Valve
Been thanked: 504 times
Post by cn90 »
Update,
Purge Valve Bosch 0280142300.
Took it out (it sits between the battery and the radiator).
- Two Torx screws later, it is out.
- Changed all hoses (old hose...dry rot)
- The old hoses bonded to the line, so used a utility knife and slice it gently along the hose to split it.
- Blow through valve (NOTE the arrow), it blows right through!
Should have been closed when out of the car.
- No need to disassemble the valve etc.
- Spray Carb Cleaner into both ports.
- Repeat this 10x until no more black gunk comes out
- Now blow through the port (again Note the arrow), it is shut.
So the Carb Cleaner trick did the job!!!
- Installed, all is good.
Anyway, just want to share this FREE fix with you guys!
JeffersV70
Year and Model: 1998 V70
Post by JeffersV70 »
I'm going to have to try this, I've been running a p0455 code for 2 years now.
1998 V70 N/A / Red / 127k
1998 V70 N/A / Black / 109k
Post by cn90 »
You will see that when you remove the Valve, it blows through. The closing mechanism has gunk build-up inside (see the photos at the beginning of this thread) that prevents it from closing. So it stays open all the time, thus the P0440 code.
Once you clean it with carb cleaner, you will see that the valve now closes properly.
It has been a few days, and the code P0440 is gone (usually this code comes up within 1-2 days).
So I am happy about this free fix.
Post by cn90 »
Attached is the photo of the Purge Valve Bosch 0280142300 for those who want to take it out and clean it:
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
cn90 wrote:Attached is the photo of the Purge Valve Bosch 0280142300 for those who want to take it out and clean it:
What was the cleaner, brand?
Dirk1966
Year and Model: V70 2.4 D5 2004
Post by Dirk1966 »
I was looking for this purge valve on my ME7 . Should it be a similar item or is it different?
Where you have the purge valve in the picture i have a different item.
On my car i found a square Valve?
Item codes
7.22517.01
12V 98T294
9125243
marshappynation
Year and Model: 850 1996
Has thanked: 2 times
Post by marshappynation »
There seem to be at least 3 purge valves for the 1996 850. I don't know what dictates which yours will have. One attaches to the cannister (FCPEuro part 9135805). Two attach to the radiator shroud: Bosch 0 280 142 300 and 0 280 142 302. Those look similar outside but are different inside. The suggested repair procedure is based on the 302. My car, a 1996 850 non-turbo, has the 300. It doesn't have the o-ring so I didn't try to repair it.
songzunhuang
Year and Model: 98 V70 T5
Been thanked: 30 times
Post by songzunhuang »
The glue on mine was so permanent that I cracked the housing trying to pry it apart. Also, I had no evidence of an o-ring! Did it disintegrate with age? I tried to RTV the inside and epoxy the case, but I am doubtful. I think a new valve may be in my future. We will see. Thanks for the tip none-the-less.
Song Huang
1998 V70 T5 - Hurt your eyes red
2000 Honda S2000 - Berlina Black
1984 BMW 633CSi - Dolphin Grey
2024 Lexus - Eminent White Pearl
2004 XC90 T6 AWD Ruby red (RIP)
songzunhuang
JeffersV70 wrote:I'm going to have to try this, I've been running a p0455 code for 2 years now.
Haha, I think mine has been more than 2 years. I even took it to the dealer to get it "fixed". It lasted a few days - long enough to pass smog inspection test, but then would always come back. It'll be interesting to see if this is the solution for me.
Song Huang
talileigh
Year and Model: 2004 volvo v40
Post by talileigh »
Can this fix be adapted for the square purge valves from a v40/s40? Has anyone had any luck fixing these ones? If so-any information or instructions would be greatly appreciated.
