Crankshaft bolt
sdcarruthers
- Year and Model: 940 Gl, 1992
Crankshaft bolt
I have a '92 940 Gl. The timing belt lost 13 teeth and I am trying to change the belt myself. I am having trouble loosening the Crankshaft bolt. Is the bolt reverse thread or normal? How can I get this bolt loose? Any advice would be greatly appreciated! Thank you!
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
13 teeth?... Hmm...
This is an interference type engine; I have trouble believing you did not bend some valves in there...
The bolt that holds the CS pulley and sprocket is RH-threaded, you will need an impact air tool to break it loose, or you can put a DIY counterhold on the pulley, and just undo it with a ratchet.
(Some people use the 'Mickey Mouse method' with the starter, however, I would strongly oppose to that!)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The B230F is a non-interference engine so should have no bent valves. The 16 valve B234F is an interference engine but this is only in the 940GLE.
Several methods of taking out the crankshaft bolt have been discussed on this forum in the past. The safest, and in my opinion, the easiest method is to buy the special tool for holding the crank shaft. This is available from our sponsor IPD. However, if you are good at metal work or know someone who is you can make your own tool following the instructions on Brickboard.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 1964 Views
Last post by Kazthebassman
- 12 Replies
- 3068 Views
Last post by JimBee
