Replaced the engine in my sisters 2000 S70 FWD. 2.4 liter 4 valves/cylinder variable valve timing. She had a cracked radiator and ran the car out of coolant then then blew the motor. Not knowing the extent of the damage I bought a used engine and swapped it out for her. Engine is in one piece and pretty complete. Lots of good used parts or possible rebuild. I don't know the extent of the damage to the engine. Includes MAS airflow sensor, intake and exhaust manifolds, head still attached to block. Oil pan is cracked. The salvage yard set the used engine that I bought on a bolt and cracked the oil pan so I took the pan off the blown motor and used it on my replacement engine.
Engine does not have the starter,alternator or power steering pump.
Feel free to ask any questions. Located in Boone NC, will help with delivery.
pat 864-477-8958
Make offer
