I took off the OMP strut brace on my 850 after 10yrs, and...
This topic is in the MVS Volvo Repair Database » Ten Years Later, 850 Still Flexy
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2654 times
Been thanked: 1248 times
Volvo Repair Database I took off the OMP strut brace on my 850 after 10yrs, and...
Post by matthew1 »
... and the most notable observation was that the driver's door opens/closes differently when I park on uneven surfaces, especially where one wheel is more or less elevated than the others. The door contacts the frame (of course with the seal in-between) in different places... it feels different and sounds different.
This reinforces, no pun intended, that the P80 is a flexy platform, and finding ways to brace it make it a more predictable handling car, if not quieter and smoother-riding.
Thus the use of the rare C70 convertible subframe brace on other P80 models. All this is not news to the P80 community as much as it is me posting just to post. :D
Also -> Amazon link
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
And also the added bracing if the car is involved in an accident.
I would have repaired my recently written off '99V70 if the struts weren't closer together after the impact by around half an inch (the subframe was also bent so I called it quits)
Some of the extra movement in your body can be attributed to time related chassis flex. The car would have been slightly stiffer when new overall.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Mini-keg to work on a car? Hmmmmm...
'98 S70 T5
2016 Chevy Cruze Premier
Ben850
Been thanked: 7 times
Post by Ben850 »
I did notice a substantial feel after intalling the OBX strut brace. It was meant to be additional support for the unibody repair that I had done. It is not a high end racing piece by any means, nor is the '93 n/a.
tow yard 1.jpg (73.75 KiB) Viewed 14355 times
disassembly and assessment 2.jpg (72.16 KiB) Viewed 14355 times
Regardless, I noticed a stability that was assuring.
I think it was diet pepsi inspired.
It's much better now.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
eld4au6
Year and Model: 96 855R, 96 855R
Post by eld4au6 »
^ glad you posted the images of your car before. My r has those same kinks where the inner fenders are tweaked a little.
I can see the price of strut bars rising... and it looks like I need one.
jacobharding
Year and Model: 87 740 T.I.
Post by jacobharding »
Where do you get one of those? I am speaking of the brace - not the keg.
I am not an expert mechanic, but I will attempt any repair. Worst case scenario is I screw it up worse than it was.
87 745 Turbo Intercooler...333k, all original!
96 850 Turbo wagon "totalled - parting out"
94 850 Turbo wagon waiting for tranny
2 94 855's gone
They're all gone now....
Ben850
Post by Ben850 »
Here is mine which seems to be available again. They were out of stock everywhere when I was looking for it, so I ended up paying more than a new one.
http://www.ebay.com/itm/OBX-Front-Strut ... 7b&vxp=mtr
Ipd has one that people seem to like. You can see the price difference. It is more of the "Track" type, whereas mine is a functional showy type.
http://www.ipdusa.com/products/6520/114 ... -p80-black
Have Fun.
vjaneczko
Year and Model: 2006 S60R
Been thanked: 6 times
Post by vjaneczko »
Ben850 wrote:Here is mine which seems to be available again. They were out of stock everywhere when I was looking for it, so I ended up paying more than a new one.
I have this one and highly recommend it, especially for the price. One suggestion if you get it; make sure the hex bolt is facing towards the engine and the nut is facing the rear of the car. It'll make it much easier to tighten everything down.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
c70_lindsay
Year and Model: 99 S70 T5.
Post by c70_lindsay »
Could you explain the C70 convertible subframe brace a little. Where does it go? How much difference does it make? Do I want one for my C70 coupe? (I am assuming it doesn't have one). I dread the day when I start getting door rattles and window leaks on the car. As soon as I saw the pillar-less windows on it I knew it would only be a matter of time before it started makin' a racket. Would bracing the frame mitigate these problems?
matthew1
Site Admin
Post by matthew1 »
c70_lindsay wrote:Could you explain the C70 convertible subframe brace a little. Where does it go? How much difference does it make? Do I want one for my C70 coupe? (I am assuming it doesn't have one). I dread the day when I start getting door rattles and window leaks on the car. As soon as I saw the pillar-less windows on it I knew it would only be a matter of time before it started makin' a racket. Would bracing the frame mitigate these problems?
It goes on the belly of the uderside. Jack her up and take a look.
You probably already have one, and I have to express surprise you don't already have shakes and squeaks on the interior. :shock:
Convertibles always come from the factory with extra bracing, whether it's "built-in" or an external brace, like the one we're talking about. Part of why the convertible version of a car will weigh more than the coupe, typically.
Nearly off-topic, my roommates and I cut the roof off a 1974 Dodge Dart and it suffered no mid-car structural collapse, at least not for the next 12 months. Don't know how it fared after that.
Also -> Amazon link
