I need a working LEFT REAR Door Actuator for 1998 S70. Please PM if you have one.
PN: 8626185.
Other PNs: 9152485, 9187284, 9203219, 9203630, 9203905.
Need LEFT REAR Door Actuator for 1998 S70
JRL
- Year and Model: Several
- Been thanked: 16 times
I have 2 working ones but I have to find out which doors they're for, all are different
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
I pulled all four from a 99 V70 XC a while back. Cblackburn took the drivers and I need front and rear pas side, so rear drivers side is here if it will fit yours.
PM me if other deal falls through.
Shane
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
obayha
The weather did not permit me to check to make sure it worked. It's pretty good here today and I should get home before dark and will check it out. Shipping may be different, as it will not fit in a small flat rate box, but I will pm you with all that once I make sure it works.
I'm usually better at getting things done, but the father-in-law fell, which prompted putting up hand railings around his house. Though at 96, he's still gets around good. Just stopped driving last year...
Shane
Shane
1998 V70 T5 331,000
- Been thanked: 476 times
Thanks obayha,
I want to know if this is a Volvo Actuator (vs aftermarket).
Also, do you know the mileage of the part that you pulled?
obayha
Part number on this one is 9203005. 23/09/1998.
I do not know the mileage of the car it came from. I pulled pretty good leather seats and all door panels from the car, so that tells me with not a lot of wear on the seats that I would think maybe not a lot of miles. The car was parted because of the motor. The headlights were like new and only the drivers door panel had pulled away some.
Cblackburn put in the drivers one, so I hope it is still working or I might of heard from him. That was a few months ago.
Sorry I can't give any more info on the part. The other two are going on my car as soon as I find a longer warmer day.
Shane
Shane
1998 V70 T5 331,000
