Can anyone give me some info regarding the 850R model? SUch as production numbers, suspension, turbo boost, wheel/tire, and what else makes it an R model. THanks
CHris
R model
- Has thanked: 2655 times
- Been thanked: 1248 times
I don't know off the top of my head, but I do know even the R's specs changed from year-to-year. Including the model year will help get the correct specs.
chris
I'm mainly interested in the 1996 model. However, I know that 1995 was the first model year in America. Also, how do the Euro and American R models differ?
Rick
Direct from Volvo:
Thank you for contacting Volvo. Information regarding the 850 R series
is available online by registering for the "Owner's Circle" section of
our website and clicking on "Driving" and then "Older Model Info".
Volvo produced approximately 5000 R's between 1995 and 1997.
Drive Safely,
John Willets
Volvo Cars of North America
Specs: 95, 96, 97
1995 850 T-5R Sedan
See the 1995 850 Maintenance Schedule
Volvo's Owners Manual Library
FEATURES
Safety
Driver and front passenger supplemental (air bag and knee bolster)
Side Impact Protection System Air Bags
Five 3-point, inertia-reel belts. Front seat belts have automatic height adjustment and pretensioners
Five padded head restraints (center-rear is adjustable)
Anti-lock Brake system (ABS)
Daytime Running Lights
Remote keyless entry
Central power door locking system which can be operated from three positions, includes trunk and fuel filler lid locks
Security System
Traction control System (TRACS)
Interior
Dual Zone Electronic Climate Control with separate controls for driver and front passenger
AM/FM stereo cassette, Dolby, anti-theft circuitry,4 Channel 160 watt amplifier, CD changer capability, 8 speakers
8-way power adjustable driver's and passengers seat with 3-position memory and adjustable lumbar support
Graphite leather seating surfaces with distinct inserts
Tilt/telescopic Leather steering wheel
Black Burled Walnut trimmed instrument panel and floor console
Power glass sunroof with slide and tilt positions and sliding sun shade
Cruise control
Front and rear floor mats
Front door-panel storage pockets. Front seat back storage pockets
Long-load pass through to trunk
Tool kit
Interior cabin light delay
Two entry lights (in front door foot wells)
Four, front and rear reading lamps
Illuminated, lockable glove box
Illuminated vanity mirrors in driver's and front passenger's sun visors
Luggage compartment light
Split 60/40 folding rear seat; front passenger seat backrest folds forward
Integrated child booster cushion in rear center armrest *For children age 3 and over, weighing between 50-80 lbs (23-36kg) and between 46 and 54 in. (117 and 137 cm.) in height.
Four cargo tie-down rings
Power windows with auto down for driver's window
Trip computer
Heated front seats
Outside ambient temperature gauge with freezing warning
Exterior
Dual power mirrors with heating elements
Tinted windows
Two-speed windshield wipers with intermittent cycle
Rear-window defroster with automatic timer
Open door traffic warning lights on doors
Special Lower front Bumper and spoiler with integrated fog lights
Rear fog light
7" x 17" 5-Spoke Titanium Grey Alloy Wheels. 205/45/17 ZR Rated Pirelli P-Zero Tires; 6.5" x 16" 5-Spoke Metallic Grey Alloy. 205/50/16 ZR Rated Tires. No Charge (OPTION);
Rear-spoiler
stainless steel door sill plates
Wiper washer system for headlights
Engine
Transversely mounted, 2.3 liter, 5-cylinder double overhead cam, 4 valves per cylinder, aluminum engine block, forged vanadium steel crankshaft and connecting rods, cast-in iron cylinder liners, interior piston cooling nozzles, sodium filled exhaust valves, water cooled turbo housing, microprocessor-controlled multi-point, direct port fuel injection system with Lambda Sond. Electronic ignition system with knock sensor. Exhaust driven turbocharger with intercooler
Horsepower (SAE net): 240 @ 5200 rpm
Torque (ft/lbs., SAE net): 221 @ 2100 rpm
Compression Ratio: 8.5:1
Transmission
4-speed microprocessor-controlled automatic with lock-up torque converter and selectable shift modes (Economy/Sport/Winter) Final drive ratio: 2.54
Suspension
MacPherson strut with asymmetrically mounted coil springs, hydraulic shock absorbers, 21 mm stabilizer bar.
Delta-Link semi-independent rear suspension with coil springs, extra firm gas-filled shock absorbers, 20 mm stabilizer bar.
Tires
7" x 17" Titanium Grey 5-Spoke Alloy Wheels. 205/45/17 ZR Rated Pirelli P-Zero Tires; 6.5" x 16" 5-Spoke Metallic Grey Alloy. 205/50/16 ZR Rated Tires. No Charge (OPTION);
Steering
Power-assisted rack and pinion, 34.5 ft. turning circle, 3.2 turns, lock to lock
Brakes
Four-wheel, power-assisted disc brakes.
Front: 11-inch diameter, ventilated discs with sliding calipers.
Rear: 11.5-inch diameter solid discs; Proportioning valve on rear brakes. Three-channel anti-lock braking system (ABS); Separate self-adjusting mechanical drum parking brakes
Dimensions and Weights
Wheelbase 104.9 in. 266.5 cm.
Overall Length 183.5 in. 466.0 cm.
Overall Width 69.3 in. 176.0 cm.
Overall Height 55.7 in. 141.5 cm.
Front Track 59.8 in. 152.0 cm.
Rear Track 57.9 in. 147.0 cm.
Trunk Capacity 14.7 cu ft. .42 m3
Curb Weight 3148-3208 lbs. 1431-1458 kg.
Interior Total Volume 111.5 cu ft. 3.16 m3
Color & Upholstery
Colors Black, Yellow
Upholstery Black
Options
Sport Suspension Package 21 mm front stabilizer bar, 20 mm rear stabilizer bars, extra firm shock absorbers (OPTION)
1996 850 R Sedan
See the 1996 850 Maintenance Schedule
FEATURES
Safety
Side Impact Air Bags
Remote keyless entry with alarm
Central power door locking system includes trunk and fuel filler lid locks
Interior
SC-815 Premium Sound System with in dash CD, cassette, eight speakers, 200 watts amplifier, anti-theft coding, pre-wired for Volvo Compact Disc Changer
8-way power adjustable driver's seat with 3-position memory; 8-way power adjustable passenger seat with 3-position memory.
Split leather and Alcantara suede upholstery
Tilt/telescoping Leather steering wheel with color accents
Scandinavian Light Birch or Black Burled Walnut wood trim on instrument panel and floor console
Cruise control
Tool kit
Trip computer
Heated front seats
Outside temperature gauge
Exterior
Dual power mirrors
Tinted windows
Special Lower front Bumper and spoiler with integrated foglights
Rear fog light
7" x 17" Titanium Grey Seven-Spoke Alloy. 205/45/17 ZR Rated Pirelli P-Zero Tires; 6.5" x 16" Five-Spoke Alloy. 205/50/16 ZR Michelin MXM. No Charge (OPTION);
Rear-spoiler
Stainless steel door sill plates
Headlamp washer/wiper
Engine
Transversely mounted, 2.3 liter, 5-cylinder double overhead cam, 4 valves per cylinder, aluminum engine block, forged vanadium steel crankshaft and connecting rods, cast-in iron cylinder liners,microprocessor-controlled multi-point, direct port fuel injection system with Lambda Sond. Electronic ignition system with knock sensor.
Transmission
Suspension
MacPherson strut with asymmetrically mounted coil springs, forged aluminum lower link arms, hydraulic shock absorbers, 21 mm stabilizer bar.
Delta-Link semi-independent rear suspension with coil springs, gas-filled shock absorbers, 20 mm stabilizer bar
Tires
Steering
Brakes
Rear: 11.5-inch diameter solid discs; Proportioning valve on rear brakes. Three-channel anti-lock braking system (ABS); Separate self-adjusting mechanical rear-wheel drum parking brakes
Trunk Capacity 14.7 cu ft. 1.6 m3
Interior Total Volume 111.5 cu ft. 12.4 m3
Color & Upholstery
Colors Black, Red, White
Upholstery Alcantara Beige or Grey
1997 850 R
See the 1997 850 Maintenance Schedule
FEATURES
Safety
Driver and front passenger supplemental restraint system (air bag and knee bolster)
Prewiring for security system & front fog lights
Traction Control (TRACS)
Interior
SC-815 Stereo cassette with in-dash CD, eight speakers, 200 watts
8-way power adjustable driver's seat with 3-position memory; 8-way power adjustable passenger seat with 3-position memory;
Adjustable driver's seat with lumbar support
Split leather and Alcantara (Suede upholstery); Leather-faced upholstery (OPTION)
Leather-wrapped steering wheel with color accents
Scandinavian light birch or burled black walnut wood trim on instrument panel and floor console
Cruise control
Front door-panel storage pockets. Front seat back storage pockets.
Tool kit
Four front and rear reading lamps
Center console with cupholders.
Trip Computer
Exterior
Dual power mirrors
Tinted windows
Prewiring for security system & front fogs
Rear fog light
17" seven spoke Alloy Wheels with high performance tires
Special lower front bumper and spoiler with integrated fog lights
Engine
Transversely mounted, 2.3 liter, 5-cylinder , exhaust driven turbocharger with intercooler, 4 valves per cylinder, aluminum engine block, forged vanadium steel crankshaft and connecting rods, cast-in iron cylinder liners, microprocessor-controlled multi-point, direct port fuel injection system with Lambda Sond. Electronic ignition system with knock sensor.
Horsepower (SAE net): 240 @ 5600 rpm
Torque (ft./lbs., SAE net): 221 @ 2100 rpm
Transmission
Suspension
MacPherson strut with asymmetrically mounted coil springs, hydraulic shock absorbers, 20 mm stabilizer bar.
Delta-Link semi-independent rear suspension with coil springs, gas-filled shock absorbers,19.5 mm stabilizer bar
Tires
7x17 Seven-spoke Alloy; 205/50/16 ZR Rated tires
Steering
Brakes
Rear: 11 1/2-inch diameter solid discs; Three-channel anti-lock braking system (ABS); Separate self-adjusting mechanical rear-wheel drum parking brakes
Trunk Capacity 14.7 cu ft. .41 m3
Interior Total Volume 111.5 cu ft. 3.1 m3
Color & Upholstery
Colors Black, White, Bright Red
Upholstery Leather: Ivory, Graphite, Light Grey
Split Leather and Alcantara Suede: Beige, Grey
Plush: Beige, Grey, Graphite
Velour: Beige, Graphite, Light Grey
Options
Cold Weather Package Heated front seats, Wiper washer system for headlights, Outside ambient temperature gauge with freeze warning
Drive Safely,
John Willets
Specs: 95, 96, 97
1995 850 T-5R Sedan
FEATURES
Safety
Security System
Interior
Cruise control
Tool kit
Trip computer
Heated front seats
Exterior
Tinted windows
Rear fog light
Rear-spoiler
Engine
Transmission
Suspension
Tires
Steering
Brakes
Color & Upholstery
Upholstery Black
Options
1996 850 R Sedan
FEATURES
Safety
Interior
Cruise control
Tool kit
Trip computer
Heated front seats
Exterior
Dual power mirrors
Tinted windows
Rear fog light
Rear-spoiler
Engine
Transmission
Suspension
Tires
Steering
Brakes
Color & Upholstery
1997 850 R
FEATURES
Safety
Interior
Cruise control
Tool kit
Trip Computer
Exterior
Dual power mirrors
Tinted windows
Rear fog light
Engine
Transmission
Suspension
Tires
Steering
Brakes
Color & Upholstery
Options
- 363 Views
Last post by combatkarl
- 16 Replies
- 2292 Views
Last post by polskamafia mjl
