throwing in the towel perhaps
warcraftjunkie
- Year and Model: 2008 XC90 3.2
Yeah, i've checked the B+ cable from battery to fuse box, it's good. The alternator, to starter, to battery also appears to be good. I'm not 100% certain I've got this beat, because it's always seemed to be an electrical issue, however reseating all the sparkplugs could have been good enough. I'll be holding my breath for a few weeks.
If you can't laugh at yourself, someday you will be the only one not laughing.
08 S80 V8 - My daily driver
08 XC90 3.2 - Wife's people hauler
87 245 DL - Son's car
warcraftjunkie
Well, I think I can call this solved. I'm sure it wasn't just one thing that fixed it, but the last thing I did was pull the plugs, clean them up and reseat the coil packs.
Is it possible for the mods to change the subject on the original post to solved? I tried to do that, but I couldn't edit it.
Thanks for all the help along the way. This is the greatest community!
northernlights
- Year and Model: 850 Turbo 1994
- Location: Florida and/or Raleigh NC, depending on the day
- Been thanked: 8 times
I couldn't help but quote your dealership experience from Fall 2012 after your last post.warcraftjunkie wrote:Well, just got off the phone with the service dept. He's doing the write up now. Looks like they want 1300 for a ECU rebuild/reload, 750ish for ETM,and 450ish for MAF.
It's awesome that your appear to have solved it. It makes me fear the electronic throttle a little less, and wonder how many cars get scrapped due to flaky electrical connections.
rickybobby
- Year and Model: V70XC, 1999
Ya electrical is a pin for sure, had ETS lights (threw a low voltage code), car died while driving, changed the battery first then figured out that the alternator was dead ... $40 for a new alternator and it was back on the road, now I get P0236 and I'm not sure if I want to switch both MAP and MAF sensors... might try to find a junkyard with those and see if it helps
- 19 Replies
- 6343 Views
Last post by Richard99
- 869 Views
Last post by packetfire
- 2605 Views
Last post by volvolugnut
- 15 Replies
- 2473 Views
Last post by obayha
- 541 Views
Last post by xHeart
