Defeating the torque limit request on the Volvo 850 Turbo
This topic is in the MVS Volvo Repair Database » Defeating the torque limit request on the Volvo 850 Turbo - TCM Signals
RyanT5
Year and Model: S70 T5, 98
Post by RyanT5 »
Youre probably right :/
ARD-Lucky
Year and Model: 1994
Post by ARD-Lucky »
You could use an Arduino, Pi, or PIC to comm back and forth to the ECU or you could simply reduce limiter in the ECU for first/second without fully removing it... I'm a bit slammed now but I can do some further research on how the physical switch interrupt could be implemented if there is interest.
Few other projects to finish up first but I'm open to input!
cleven
Year and Model: 2001 V70 T5
Been thanked: 5 times
Post by cleven »
What if someone where to put a resistor in line of the wire?
RyanT5
Post by RyanT5 »
Hmm it appears i paid no attention to the basic of this thread and failed to realize this is for 850 turbos and not 70 series. Ordered my green tune yesterday and in the notes on the buildsheet requested the low gear torque limits to be reduced a bit. i wonder now if i just asked for the impossible and looked stupid? lol regardless im excited, says it shipped yesterday at 3:00pm :D
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2858 times
Been thanked: 1332 times
Post by matthew1 »
Ryan, the torque limit request signal is sent on '98s, also. See Jimmy's post regarding cutting the wire in his '98 S70 company car. So, no, Lucky won't think you're uninformed. Until he reads this. :D
Also -> Amazon link
RyanT5
Post by RyanT5 »
matthew1 wrote:Ryan, the torque limit request signal is sent on '98s, also. See Jimmy's post regarding cutting the wire in his '98 S70 company car. So, no, Lucky won't think you're uninformed. Until he reads this. :D
Hey lets all make fun of the volvo newb and his stupid questions! haha thanks matt 8)
jacobharding
Year and Model: 87 740 T.I.
Post by jacobharding »
Very interesting topic. I just read it through for the first time. I did not know about the ECU limiting boost on take off. It has been my experience, on rare occasion, that I can smash it from a stoplight and get amazing torque and wheel spin from a dead stop. This is rare and I am pretty sure road surface is not to blame. I can't help but wonder, after reading this thread, if a fault in the ECU or it's wiring could be to blame.
Also if you want more power on takeoff I have found just a little bit of power braking goes a long way. I have laid many 50+ foot black stripes from the light right through second gear.
I am not an expert mechanic, but I will attempt any repair. Worst case scenario is I screw it up worse than it was.
87 745 Turbo Intercooler...333k, all original!
96 850 Turbo wagon "totalled - parting out"
94 850 Turbo wagon waiting for tranny
2 94 855's gone
They're all gone now....
mercuric
Year and Model: 1997 850 T5
Post by mercuric »
Was cruising around VIDA and happened upon some information on the torque limiting... 437: Signal Description AW50-42 Connector B.
According to the information, B1 is at battery voltage with the ignition on, but goes to Ulow ("approx 0v") both on engine idle and torque limit.
B4, the limit request ACK, stays at battery voltage with the ignition on or idling, and goes Ulow on ACK.
Chart attached, PDF.
Interesting thread, y'all! :mrgreen:
Not sure I'd want to do this, my T5 seems quite able to shred tires as it is, but I did like the suggestion of wiring it into the TRACS switch.
Also, in regards to the timing retard for gear shifts, that apparently only applies to ECON mode:
Shifting (cars with electronically controlled automatic transmission)
Just before shifting a signal comes from automatic transmission control module (TCM) (11). The engine control module (ECM) replies by retarding ignition for a short time. This gives a temporary reduction of engine torque and the shift is smoother. This function is normally only connected when the driving program selector for the automatic transmission is in economy position.
vida_aw5042_connectorB.pdf
(28.37 KiB) Downloaded 571 times
Reys
Year and Model: 850T estate '96
Post by Reys »
Matt, did you end up wiring a 12v source to that cut wire?
matthew1
Site Admin
Post by matthew1 »
No, not yet. Right now it's an "eventuality", unless I get brave sometime soon.
Also -> Amazon link
