DGM,
Thanks a ton. Have resolved to do the entire job at once.
I will post my results.
Mike
PTC Nipple removal and cleaning
PTC Nipple Vacuum Line Routings
Michael Dixon
- Year and Model: V70AWD SE 2000
DGM
- Year and Model: V70 2.4i 2005
- Been thanked: 3 times
Good for you. On the long run you will save.Michael Dixon wrote:DGM,
Mike
Replacing a RMS (rear main seal) is time consuming and expensive
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
- Has thanked: 2650 times
- Been thanked: 1240 times
Looks like it's my time for a PCV job. Last done on my 850 in 2007, roughly 30k miles ago.
Here's my PTC nipple cleaning photos from last night, halfway through the cleaning + my new elbow solution (3/8ths Gates rubber heavy vacuum hose) already applied:
Worn, broken elbow next to it.
A little brush to get inside the housing is ideal. That and parts cleaner of whatever type.
It got it off and back on without taking off the intake tube.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
You've got smaller hands and/or more patience than I do!It got it off and back on without taking off the intake tube.
'98 S70 T5
2016 Chevy Cruze Premier
rmorse wrote:What I'm confused about it how Matt did all that work with only getting ONE finger dirty...
There's a hole in the finger of one glove.
Power Jets
- Year and Model: 850 GLT 1994
I've read through the discussions, but is there resolution on the functionality of the "PTC Nipple"?
From the photos I see a metal aperture restricting the PCV flow to the inlet manifold and a vacuum connection. A vacuum driven valve? (perhaps to prevent PCV backflow contaminating the mass flow sensor during idle). Or maybe the vacuum connection is achieving something similar by scavenging the flow when idled.... if so there would be gunk up the vacuum tube? Or maybe just a vacuum pickup to drive something else?
So, does anyone have a definitive theory of operation? Thanks!
jblackburn
The intake side of the turbocharger provides vacuum (to the PCV box) when there IS no vacuum from the intake manifold because positive pressure is being forced through by the turbo.
When the turbo is not boosting (e.g. idle), the small vacuum line provides vacuum to that area directly from the intake manifold.
'98 S70 T5
Power Jets
John, thanks, I should have been explicit... mine is NA but the principle is likely identical.
So the vacuum line is actually extracting PCV gas from the throttle region when the car is at idle, and is thus prone to blockage. I'm thinking about increasing the diameter of the vacuum line to delay the onset of blockage and reduce idle pressure build up.
Makes sense? Thanks!
jblackburn
On an NA, the small vacuum line simply adds vacuum to the area when the throttle body plate is closed at idle.
'98 S70 T5
- 561 Views
Last post by johnbuilds
- 861 Views
Last post by kahl
