New shocks and struts (what to get)
Dieterly
Year and Model: V70 -04
Has thanked: 2 times
Post by Dieterly »
My wife's -04 v70 new shocks and struts (basically just normal every day driving). She doesn't need the high end stuff but something middle down the road would be nice, any suggestions?
Yes, I used the search function and that's why I'm confused what to get :D
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2650 times
Been thanked: 1240 times
Post by matthew1 »
Boge (OEM)
front http://www.ipdusa.com/products/5868/112 ... 60-v70-s80
rear http://www.ipdusa.com/products/5870/112 ... 60-v70-s80
If you get them there, please tell them MVS sent you. Thanks in advance.
These are the best non-performance shock/struts. Trusted brand.
Also -> Amazon link
Dieterly
Post by Dieterly »
Order placed...
Tonyx
Year and Model: 2001 XC70
Has thanked: 3 times
Been thanked: 8 times
Post by Tonyx »
I replaced mine with the exact same ones Matt recommended. Nice shocks.
Assuming you are DIY, I suggest also looking into stabilizer end links. With the vehicle on the ground and front wheels pointed straight - see if you can easily rotate the links by hand. This for both front and rear. Since you will need to undo the links during shock replacement, it would be great time to refresh the links which are usual cause for rattle noise or sloppiness in handling.
Also IPD sells heavy duty strut top mounts, rounded mold pieces that cups the front springs. Middle rubber wears out which causes sag. If you have gap greater than 3/8inch between strut top washer and top of strut top bearing(visible from top with hood open) you will want to replace the strut top mount. Since you will need to disassemble it to replace the strut, now will be great time replace this as well. I've done it twice because the I did not use the IPD heavy duty unit the first time. The first set lasted less than a month here in Michigan winter roads.
2003 XC70 230K and counting..,
