KYB shocks and struts:
http://www.fcpeuro.com/products/volvo-s ... 850-sr1001 http://www.fcpeuro.com/products/volvo-s ... 850-kg5747
Has anybody use these?
How do they compare with Sachs and Monroe?
I'm looking for something that wouldn't transfer every concrete joint on crappy Minnesota roads.
KYB shocks and struts - has anybody used these?
EstVolvo
- Year and Model: 2000 V70
First I tried one of the search fields and no information about KYB showed up.
Now I tried second search field and tons of stuff about KYB showed up - I will take a look at it.
SpeedyPete
- Year and Model: S70-T5, 1998
Yes, I have these on my car now. I must say that I was slightly over due for replacement (165 K miles) of the originals and got stuck on a road trip with these being my only option at the time. I only have about 5-10 K on these now and I am satisfied with them. Keep in mind my car is stock and I do not drive it hard and aggressive. It is difficult for me to compare the stock suspension with these only in that I was used to driving on a worn out noisy clunking suspension. I will say however now everything is quite and tight. If your on a tight budget and use the car as a daily driver go for them. They will do the job just fine. Also you must change all of the bushings and mounts. Regards, SpeedyPete
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
I had them on a Maxima, Grand Cherokee and my current 300c. I like them and have no complaints.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- Has thanked: 1836 times
- Been thanked: 1709 times
Can't talk to the KYB product although heard good things about their product. On my last 850 and my current 2000 V70R I have used Bilstien Touring shocks. They are taught but I like them better than the Bilstien HD's that were on the V70R. They made your fillings rattle.
On our 98 V70XC replaced old shocks with OE (Sachs/Boge). They run really well also and do absorb the bumps well.
As advised, replace the top spring seats and check the ball joints and control arm bushes.
