i have a 1999 s80 t6 and my fan only turns on when the car is turn off, i change the cooling temperature sensor, termostat, and the radiator fan ,temperature sensor reaches half way and the fan won't turn on. what else could it be so the fan would turn on and it wont overheat.
these are the codes that im getting
p0102 mass air flow sensor low frecuency
p0118 ect sensor circuit high voltage
1999 s80 t6 fan problem
Does your temperature gage behave normally?
Does the engine overheat?
2003 v70 2.5tawd black/black 120miles
2007 nissan altima 2.5 cvt 107miles
2001 xc70 211 miles " collision"/ parts car
1994 850 turbo 315miles 5 speed "stoped fixing it"
the temperature gauge does not behaves normally sometimes it stays all the way to the bottom and sometimes it works and i just change the temperature sensor and is doing the same thing and the engine does not overheats because i dont see the reservoir boil
