$2000 to spend on mods for an 850
Alden
Year and Model: 850, 1996
Post by Alden »
Let's say you're given $2000 to spend on the following car; 1996 Volvo 850, NA, 5 speed manual, M56H. Everything on the car is in perfect and functioning condition. The main goal would be to get faster times at autocross. Currently, the Volvo only has IPD sport springs.
Things that you can't buy
A turbo swap
A turbo Volvo
Tires (I have R-comps, semislicks, and all seasons)
Aesthetic things for the exterior/interior
As of right now, I have two choices
1. IPD track-spec sways, Bilstein HDs all around, IPD strut tower bar, Poly bushings, EST cat-back exhaust, and then find something else to blow the remaining $500 on.
2. Full roll cage ($1000), bucket seats (600), 5-point harnesses ($200), stripped interior, weight reduction, and squeeze my wallet for IPD sway bars.
Ideas anyone?
Here's a picture of the lolvo
Ben850
Been thanked: 7 times
Post by Ben850 »
You could do the throttle plate modification for free. It does help the response.
See performance and tuning. N/A throttle body mod.
Plate tools.jpg (97.6 KiB) Viewed 1437 times
comparison plate.jpg (54.29 KiB) Viewed 1437 times
Throttle body done.jpg (63.13 KiB) Viewed 1437 times
throttle installed.jpg (38.28 KiB) Viewed 1437 times
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2664 times
Been thanked: 1256 times
Post by matthew1 »
^ Ben has good info on the N/A throttle plate mod. Go to the last page, or start at the beginning, 2008 or so.
Big brake mod? You'd need bigger wheels... those Cetus won't work. Sixteens -- but not Columbas -- may work, and 17"s will work.
Pretty
Also -> Amazon link
Alden
Post by Alden »
matthew1 wrote:^ Ben has good info on the N/A throttle plate mod. Go to the last page, or start at the beginning, 2008 or so.
Pretty
Well damn, that's not happening then. I have 16" columbas for every day, and those 15 Sport Edition wheels in the picture for autocrossing
matthew1
Site Admin
Post by matthew1 »
Depends on what side of the Grind Calipers for Columbas you fall on.
Also -> Amazon link
Alden
Post by Alden »
matthew1 wrote:Depends on what side of the Grind Calipers for Columbas you fall on.
I'd be more than happy to, but I still need to fit them on 15" wheels for these guys
and
burnout8488
Year and Model: 1999 S70 AWD
Post by burnout8488 »
I'd go with option 1. Sways and brakes will make it an animal with the tires you're running. Keep the interior, these are pretty nice comfortable little luxury cars if you keep them detailed and vacuumed inside!
Option 2 just ruins the car, IMO.
Do you have a known good set of OEM control arms installed?
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
Alden
Post by Alden »
burnout8488 wrote:I'd go with option 1. Sways and brakes will make it an animal with the tires you're running. Keep the interior, these are pretty nice comfortable little luxury cars if you keep them detailed and vacuumed inside!
That's honestly what I'm leaning towards. And yeah, the control arms are in great condition
mercuric
Year and Model: 1997 850 T5
Post by mercuric »
#1 sounds like a great plan, but I might be personally more tempted to go with Koni adjustables instead. Then again, HD's might be better for cross... cross isn't my area of expertise. HD's also cost a bit less.
Lucky from ARD has also been doing some N/A tuning lately, he has a really interesting project going tuning a N/A 850: http://volvospeed.com/vs_forum/topic/16 ... rbo-build/
Looks like it's still a WIP, but when he's done he very well may be able to set you up an ECU with improved fuel/ignition maps -- He's a well respected tuner for sure. The OBX header he mentions looks like a neat piece, too: http://www.obxracingsports.com/products.php?pk=1839 -- but no good unless this is a dedicated track car, because if I understand cali laws properly you can't modify anything behind the last O2 sensor. If it's a track car, that header might be a nice addition to the exhaust. Lucky also knows what to do to delete the rear O2 sensor, allowing you to remove the cat while you're at it for even more exhaust flow / less weight.
matthew1
Site Admin
Post by matthew1 »
mercuric wrote:Lucky from ARD has also been doing some N/A tuning lately, he has a really interesting project going tuning a N/A 850: http://volvospeed.com/vs_forum/topic/16 ... rbo-build/
Ahem.
No Turbo? No Problem! Part 1
No Turbo? No Problem! Part 2
No Turbo? No Problem! Part 3
Also -> Amazon link
