Power Steering noise at low speed
This topic is in the MVS Volvo Repair Database » Power Steering Noise At Low Speed 2004 V70
dejongmc
Year and Model: 2004 Volvo S80
Volvo Repair Database Power Steering noise at low speed
Post by dejongmc »
Car: 2004 V70 NA - 98,000 miles
About 3 months ago I had a soft noise when turning the steering wheel to the left or right at idle or low speeds. I replaced the old power fluid with Mobil1 Dexron III and it went away.
Now, after 3 months, the noise is back and but the fluid is still clear.
I'm suspecting the power steering pump, but I'm not sure.
Anybody else experienced this before?
1997 850 NA Wagon - 261,000 miles - Is no longer
2004 V70 NA Wagon - Saved my life
2004 S80
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Do you see bubbles in the fluid when pump works?
dejongmc
Post by dejongmc »
I will look tonight or tomorrow.
If I see bubbles, what would that indicate?
2004 S80
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
2004 fluid should be Pentosin CHF11 not Dex-III, the Pentosin is a green coloured fluid - Mike
dejongmc
Post by dejongmc »
The specifications just say ATF fluid, so I assumed Dexron III.
Link: http://new.volvocars.com/ownersdocs/200 ... .htm#pg148
2004 S80
dejongmc
Post by dejongmc »
Mikealder: Did you mean Pentosin CHF202?
2004 S80
IVIUSTANG
Year and Model: 2006 XC70
Been thanked: 4 times
Post by IVIUSTANG »
dejongmc wrote:Mikealder: Did you mean Pentosin CHF202?
CHF11 and CHF202 are both compatible.
Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires :D
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
dejongmc
Post by dejongmc »
Thank you guys for pointing me in the right direction.
Last Saturday I flushed my power steering fluid with Pentosin CHF202 and the noise has gone away.
CHF202 is the new an improved version of CHF 21S, and it is cheaper too. I bought it at O'Reilly for $16 per bottle (1 liter).
Flushing this system can be done by one man, but if you have an extra pair of hands available use them. When flushing, the fluid comes out very fast and it is only 1 or 1,5 liters you have to get out. It just took a few seconds. You need to have 2 new bottles of CHF 202 ready to fill. All together I used 1 and 3/4 of the new CHF 202.
2004 S80
airbusguy
Year and Model: 2004 C70
Post by airbusguy »
I have the same story, bought a C70 that had no noise at all; when I picked it up to drive it home, the guy had topped up the power steering fluid with dextron. By the time I got home, it was noisy. Flushed it with the CHF202 and good as new.
tigmaned
Year and Model: blacked-out V70 04
Post by tigmaned »
another power steering post...good.
if our owners manuals are telling us to use ATF, then what is this Pentosin CHF202?
like in another post i just did a drain and fill with actual power steering fluid... but don't want to wreck my p/s....
