new guy posting, volvo 850 turbo wagon boost problem
cookiemonster131
Year and Model: 95 855
Post by cookiemonster131 »
okay so here is my story. 170,000 miles on a 95 Volvo turbo wagon automatic.
timing belt done at 140k
new parts in past 5k
snabb downpipe, all silicone intercooler hoses, new vacuum lines, new pcv system, new ipd heavy duty compressor bypass spring (blue spring), ipd stage 1 computer tune, new plugs wires cap and rotor, and an open air filter.
it had a stutter in the boost build up but always made strong boost according to the factory gauge. after installing the bypass compressor spring it was building less boost and still had the stutter. So I ordered the IPD HD TCV and replaced it today. I went per the programming instructions from IPD. I am building a little more boost than I was but not as much as before the mods. also it is still stuttering...
anyone got any ideas? I am a mechanic by trade so I am not stupid but I do not want to keep throwing parts at this car. I was thinking maybe the wastegate diaphragm is bad but it doesn't seem like it would stutter seems to me it would just not hold any boost...
any help is much appreciated!
Thanks ahead of time
Cookie
Marcobrick
Year and Model: 2003 V70T5
Has thanked: 3 times
Post by Marcobrick »
I think a bad wastegate diaphragm is more likely to lead to boost spikes and/or overboost? Double check ALL turbo hoses, vac lines etc and their routing. When you say "stutter" do you mean the boost is fluctuating, or is the engine actually stuttering like a misfire or bad surge?
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
cookiemonster131
also i forgot it also got 2 new VOLVO o2 sensors.
stutter as in it is pulling and looses power and picks back up. plus the boost is not building up in the gauge like it was before all of this started. i realize the stock gauge is not great but it is still a good baseline.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2654 times
Been thanked: 1247 times
Post by matthew1 »
Check TCV vac lines are correct.
Also -> Amazon link
cookiemonster131
just checked the tcv lines again and they are correct per IPD instructions
matthew1
Site Admin
Post by matthew1 »
Ensure that the underside of this large intake hose is not slipping off.
Reason: removed irrelevant info about P2 models, thought OP had a P2
Also -> Amazon link
cookiemonster131
just checked all around the intake hose and it is securely on correctly on both ends... :cry:
matthew1
Site Admin
Post by matthew1 »
Wastegate diaphragm/spring then. I'm with Marco. It's a '95, all OE is nearly 20 years old.
Also -> Amazon link
cookiemonster131
thanks for the answer everyone. So matthew you are in agreement with me that the wastegate is bad most likely correct?
matthew1
Site Admin
Post by matthew1 »
To me, it's just the most likely thing after the next.
Given the symptoms: bad gasoline (maybe) -> vac lines -> big hose -> TCV -> new TCV -> new CBV
Also -> Amazon link
