PTC Nipple removal and cleaning
This topic is in the MVS Volvo Repair Database » PTC Nipple Vacuum Line Routings
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Re: PTC Nipple removal and cleaning
Post by jblackburn »
xHeart wrote:
matthew1 wrote:Yes. You might see a P0422 if it burns during driving and sets off this front O2 sensor code.
Dr. Matt.
The CEL checkup at Advance Auto Parts today is indeed P0422. What'd ya know.
Can't wait to go to a steelership and get ripped off.
Donation time.
None of that.
There's an "extension" thingy that you can buy that just attaches on to the O2 sensor plug to keep oil from getting in the wire and fouling the sensor. It was designed to prevent exactly this problem from occurring.
'98 S70 T5
2016 Chevy Cruze Premier
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
jblackburn wrote:...
Is this a volvo part Justin?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1242 times
Post by matthew1 »
Not a blue box item. 109553 - Oxygen Sensor Spacer
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
$23
Also -> Amazon link
xHeart
Post by xHeart »
I will clean up the PTC nipple.
Removed the items circled in red. As cn90 suggested, the green arrow is a location near the firewall for 16" long 1/4" flat-head screwdriver. Here, I am able to loosen the clamp screw at the other end of intake tube connecting to turbo.
Preparing the access...
xHeart
Post by xHeart »
Progress.
The negative terminal at the battery was disconnected at the outset which is located at the rear of the wagon.
Removing the power supply cables at the engine makes job easier. Here are few photos...
unscrewed air-box at the MAF and removed
unscrew anchors holding power supply cables...
...put it to the side with bungee cords...
xHeart
Post by xHeart »
Unhooked the Booster Control Solenoid from under the air-intake cover, and set it aside.
The three connections are visible, pulled off the purge hose after a twist, bruised fingers. Used the flat-head screwdriver to take Oetiker clamp off PTC hose.
looking at the three connection around PTC
xHeart
Post by xHeart »
These look clean. The light comes through, no build-up found anywhere near. What am I missing?
PTC and two vacuum hose nipples
xHeart
Post by xHeart »
There is small buildup on sensor's electrical portion (pictured left). The inside of two-pin retainer at PTC is wet also (pictured right).
I am wondering why is it wet. Is this normal?
Would it mean there is a crack somewhere in PTC component, is it shot?
Would a spray with carb cleaner before putting it back together help it?
sensor at PTC
sensor at PTC
xHeart
Post by xHeart »
The air-intake tube was unexpectedly clean, PTC nipple with no buildup.
Here is the last item, the turbo itself.
Next step would be to wipe it clean.
the fluid travel at turbo...
