'93 940 loud injectors
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
e777
Year and Model: 1990 740
Has thanked: 11 times
Post by e777 »
Hello,
In December I fitted a rebuilt head to a newly acquired 93 940 wagon (purchased from the original owner with 215k miles).
The car runs beautifully. But, there is a persistent loud clicking coming from the injectors. I am 100% sure it is not the valves. The valves are within spec and I determined via the ol' mechanics stethoscope (a long screwdriver place to the ear) that the sound is definitely coming from the injectors.
Has anybody experienced this? What's the deal? :?
Wagons:
93 940
91 240
90 740
86 740
rgk
Year and Model: Gray 88 245
Post by rgk »
I used to think a strange ticking sound was coming from my lifters or injectors until I realized the sound stopped when the car went into third gear. It turns out second gear is a bit noisy in my 245.
Have you tried cleaning the injectors and replacing o-rings and caps?
rgk -- was dickdeadly
e777
Post by e777 »
Thanks for the info. Yes, that is something I should definitely do. Of course, I have had other Volvos whose engines and injection components were very worn and they never sounded like this. It almost sounds like a diesel engine at times. In any case, I will do the injector seals and caps and see if things change. Cheers.
Wagons:
93 940
91 240
90 740
86 740
rgk
Post by rgk »
No problem, I hope it helps. My local auto parts store had a kit with o-rings, cap, and all. The old caps were a bit stubborn, but came off with some prying.
