2005 S40 2.4i correct rpm at idle?
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
4S7
Year and Model: 2005 S40 2.4i
Post by 4S7 »
Can anyone answer the correct idle RPM for this S40? Mine is always right around 7-800 but when I turn in the ac it drops to 5-600 briefly then comes back up. Been reading a lot about the throttle body on this vehicle needing to be cleaned and or replaced due to low idle rpm and stalling. I'm trying to do some planning if mine seems to be working improperly.
quaverous
Year and Model: 2006 S40 T5
Post by quaverous »
I have a t5 and when I turn on the AC it doesn't impact the idle. Not sure if that helps but I figured some information is better than none.
