Power Antenna Removal and Repair
This topic is in the MVS Volvo Repair Database » 850 Power Antenna Removal & Repair
Fish stick88
Year and Model: 1994 - 850 Sedan
Post by Fish stick88 »
Since last winter I've been going without a power antenna, which often gave me little or no reception.
I finally decided to tackle it :D
I've created a photo collage as best as I could, I check back often so if you have any questions feel free to ask.
I Couldn't hear the motor even trying to run, but i figured i would give it a shot
First off
Take out the plastic stops, turn them 1/4 turn either way. There are 3.
PLEASE Comment on how i did and how my next one can be better
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
burnout8488
Year and Model: 1999 S70 AWD
Post by burnout8488 »
The nut for the top of the antenna that sits on the fender is 16mm, not 17mm, although the 17mm probably still works. Nice writeup! I've done about 3 of these, the first time was a learning experience and took FOREVER :-P
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
Fish stick88
Yeah, it took awhile, I tried to be as clear as possible and 15megapixel photos take forever to upload. i took more, just didnt post them
robotarmy
Year and Model: C70, 2003
Been thanked: 4 times
Post by robotarmy »
Thanks for this write-up! I had the whole thing removed from the trunk before I found this post. It helped a lot.
You asked for suggestions, so here goes. I hope these don't sound too critical. Basically, when you do one of these, you are trying to communicate your thoughts to another. Spelling and punctuation go a long way. Try using a text program to create your text and check for spelling and grammar before pasting to Photoshop. (I just misspelled "grammar," but fortunately, this post has a spellchecker). Also, use a bolder, brighter font when composing the frames.
It is awesome that you are even willing to take your time to do this post—a completely generous act—keep up the good work. Thousands of Volvo owners are in your debt!
:P
Cheers,
Fish
kwc
Year and Model: S70 1998
Post by kwc »
Your instructions for removal are great. But, now I need to reassemble it and I can't figure out just where to place the gear strip. Could you show or tell me just how to replace the gear strip>
Thanks. Half way there.
Fish stick88
extend the antenna mast all the way and then wind the gear with the strip on it by hand. Shouldn't be too hard.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Here is a video:
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
rspi wrote:Here is a video:
After watching the video Robert I can do this repair. Thank you.
Where will i find replacement antenna mast - PN, make, online order source?
kwc
Post by kwc »
Thanks for the quick reply. Maybe more detail of my problem will help. The antenna will rise one section. The second and third sections will not come up. I cannot even pull the sections up so maybe they are held/stuck by the plastic gear strip? I cannot get the mast piece off to clean or inspect. Any ideas on how to get the first major section of the mast loose? I'm guessing the plastic gear strip is either broken off in the mast, or there is something jamming the second and third sections from rising. I would appreciate any thoughts you may have on this.
I have taken the thing completely apart, but I cannot get the mast loose to clean/inspect it. Thanks for any info you can provide.
kwc
Fish stick88
I'm not exactly sure on that. Its been a couple years, but as i remember the mast does have some of the gear strip inside so it could jam and break off even more sections...
Like I said. I'm not quite sure.
