1994 Volvo 850 Turbo PCV Replacement
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Re: 1994 Volvo 850 Turbo PCV Replacement
Post by jblackburn »
ManManOhMan wrote:Start from the PTC Nipple and just work my way back?
Does it matter which open port I use on the tree?
Also, do you think 8mm hose would be okay to use on both the FPR and the new route from the PTC nipple to tree?
Thanks J Blackburn you have helped me a lot!
Yes to both. Doesn't matter what vacuum tree port.
Welcome! Sorry for the confusion along the way.
'98 S70 T5
2016 Chevy Cruze Premier
ManManOhMan
Year and Model: 850 Turbo 1994
Post by ManManOhMan »
Awesome, I'm all over this later on Today! I'll definitely keep everybody posted!!!!!
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
What is your engine serial number?
There are two different kits that depend on the serial number of the engine and it appears that you have the wrong kit on the car. I ran into a similar problem on a '96 NA and I had to split the new foam hose and mix and match the components. It was a mix of old and new.
From the sounds of things you don't have an original to work from so a VIDA diagram give some clues. The small line from the PTC valve on one of the versions looks like it just goes to the vacuum tree rather than the nipple on the end of the intake manifold.
Trace all of the lines from your vacuum tree that are there now and post back where they go. You definitely need a line from the vacuum tree to the fuel pressure regulator.
ManManOhMan
Thanks, I will definitely post back with the information asked.
ManManOhMan
To All,
I ran a new line from the fuel pressure regulator to the back of the vacuum tree ( the side where it's facing the exhaust manifold) and I tapped into the PCV hose and ran it to the front of the tree (on the side that's facing the fan). Here are two pictures:
New Line Tapped Into The PCV Hose AT PTC Nipple
New Line Running Into Vacuum Tree (On the side facing the Fan)
Does it matter what side of the vacuum tree the new lines are hooked too?
ManManOhMan
I still have sick smoke and oil coming out of dipstick! Please watch this video
ManManOhMan
It's just ridiculous to me that the PCV hose was hooked up to my Fuel Pressure Regulator. When I take that hose off the vacuum tree that I have it attach to now smoke flows out of it!
No wonder why I had smoke coming out of the exhaust the way I did!
The two main reasons I did this job was to resolve the smoke coming out of the dipstick and the exhaust.
Is it normal for smoke to come out of that hose though?
I hope I'm not bothering everyone with all these questions I have (they're probably dumb).
ManManOhMan
Ozark Lee wrote:What is your engine serial number?
That's exactly what I had to do, I will post back in the morning with the rest of the vacuum lines that are running to the tree.
ManManOhMan
I just want to say, I thought I had turbo before pshhhhhhhhh! I can't believe the total difference now how the car picks up!!! I know I may sound a little bit over excited but this is my first turbo car and I love it!!
Thanks to All, now I got to figure out how to get this smoke and oil from coming out the dipstick.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Try a larger hose.
