Hello,
I am getting a code for the temperature fan seized. After cleaning I am still getting the code. My question is how do you remove this part? Also, is this http://www.fcpeuro.com/products/volvo-a ... ol-9145736 the correct replacement part? Thanks for any help
Passenger’s side interior temperature inlet fan
94 850 Turbo Sedan ~223xxx D.D
97 850 NA Sedan ~265xxx Needs Transmission
- Year and Model: Many Volvos
- Been thanked: 76 times
You must be the first.jdt1249 wrote:nobody has ever encountered this before ?
I don't know how you got lost without an answer. Normally all you need to do is clean the lint and other crud out of the temp sensors, give them a small shot of oil, and they work again without replacing them. That said you need to remove the grab handle to get to assembly. The handle is held on with two screws that are behind the trim covers on the ends of the bar. Pop those trim covers off to reveal the screws and then remove the trim above the door and the A pillar to drop the headliner down.
- 4506 Views
Last post by RickHaleParker
- 4213 Views
Last post by EChem
