89 240DL Wagon, M47, Knock-preignition problem, UPDATE
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
ToeCutter66
Year and Model:
Post by ToeCutter66 »
Hello all,
I have an 89 240DL Wagon, M47, 135k miles. If I am on the highway in 5th gear with light throttle the motor pings/knocks (around 2500 rpm). If I take my foot all the way off the gas and then press the throttle 1/2 - 3/4 the way, it stops instantly, and will stay away for a while. There are no codes in either the fuel or ignition system. This car mostly sees city driving, I use 87 octane gas and it otherwise runs very well. I am about to drop the $50 on a new knock sensor, does anyone have any other suggestions?
Thanks
Kevin
Kevin
Kmaniac in California USA
Year and Model:
Post by Kmaniac in California USA »
Start with the basics. The knocking is a symptom of a lean air/fuel mixture. A lean mixture can be caused by a vacuum leak. Check the integrity of your vacuum lines and replace any that look cracked or ar leaking. Also check the integrity of your vacuum reservoir tank, as well. Next, check your intake manifold to head connection to verify the integrity of the intake manifold gasket and retorque or replace as needed. Do all this before replacing any parts, including the knock sensor.
Chris the "K MANIAC"
1986 740 GLE
(5) 1964 Chrysler 300-K's
ToeCutter66
Year and Model:
Chris,
Thanks for your input. I will check tonight for vac leaks. My spark plugs are on the whitish side, so this seems to confirm your diagnosis of a lean running condition.
Kevin
ToeCutter66
Year and Model:
I checked for vac leak. I tried with both brakecleaner and propane. I tested it at the intake manifold, injector seals, throttle body, bellows to AMM, brake booster etc. There was no change in idle. Any ideas on what to check next?
Kevin
