Hi all--
My 1992 has two problems and I'm wondering what's causing them and if they're related:
1.) Hot start problem. After the engine has been warmed up and is turned off, it won't restart until the engine has cooled down, about 30 minutes or so (depending on the weather). After 30-40 minutes, it will restart no problem.
2.) Midway during its warmup cycle, while driving, the engine will suddenly stall. After pulling over, it will restart (last time this happened the check engine light came on).
Here are the pertinent details: 135,000 miles, has recently had spark plugs replaced, as well as rotor and distributor cap and flame trap.
Any thoughts?
Thanks!
Jeff
240 Hot start/stalling problems
jeffmaciejewski
- Year and Model: 1992 244
Reason: Edited title. Please no CAPS or HELPs.
oldschoolvolvo
- Year and Model: 1979 242DL
what is the code associated with the check engine light?
-Mike
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
jeffmaciejewski
Good question, Mike--I'll have to get it and get back to you. Right now I'm narrowing it down to either the fuel pump relay or the fuel pre-pump (in-tank fuel pump).
rgk
- Year and Model: Gray 88 245
Can you hear the solenoid click in the starter when turning the key to "Start"?
If so, this means that not enough voltage is getting to the starter, and it takes a lot to turn that sucker. More than likely it's corrosion somewhere in the wiring. You can clean your wiring, tighten your connections, check your battery voltage, and check your chassis ground strap. However, you may also have to check your starter solenoid, check your ignition switch, replace the heavy wires to the battery and/or replace the battery itself.
If you can't hear the solenoid click, then you're not getting power to the starter at all. Seeing as how it only happens when it's hot, it's more than likely the first issue.
rgk -- was dickdeadly
jeffmaciejewski
Sorry everyone--I just realized I hadn't posted a follow-up!
I ended up buying a new fuel pump relay. It took only about 5 minutes to install and it cured my problem.
Jeff
Jeff
- 23 Replies
- 1015 Views
- 17 Replies
- 4340 Views
Last post by villagepc
- 48 Replies
- 11102 Views
Last post by bmdubya1198
- 21 Replies
- 6016 Views
Last post by Oitsujosh
- 38 Replies
- 5194 Views
Last post by RickHaleParker
