low compression after rebuild, 2006 volvo v50
goatkeeper
- Year and Model: 2006 volvo v50
The car overheated when I was driving it as a result of the coolant reservoir cracking on a road trip. The system lost pressure, coolant evaporated and the car overheated. I had the head checked, and it was warped but that's it. It did not blow a head gasket. I checked the compression before tear down and numbers were all over, some as low as 35. I just finished bolting the engine back together to the point where I could do a compression test. I got 95,80,65,65,120. I tried adding oil to the cylinders and it didnt make much of a difference. I replaced the head gasket, head bolts, used copper gasket spray, and cleaned everything very well. Will the compression even out and go up that much after I get it started and warm the engine? Thanks, any help is much appreciated.
Reason: Lowercased title, please no ALL CAPS or "Help" in titles. Review forum rules.
goatkeeper
Can I swap a older 2.4i into this car from another chassis?
JDS60R
- Been thanked: 3 times
Perform a leakdown test to confirm where the pressure is being lost. With compression numbers that low on a wet (oil added) test I would think you have a bad leak or the valve timing is incorrect.
I would verify cam timing using the proper test for a VVT engine and if correct I would perform a leakdown test.
Remember - pass TDC and turn another 90-180 degrees. Then turn counter clockwise to TDC. Then inspect cam and crank marks for proper set. This procedure places the VVT in the correct position for checking. VVT = variable valve timing.
Retired
- 23 Replies
- 5837 Views
Last post by precopster
- 1447 Views
Last post by Livens
