Here are the details:
Year: 2005
Mileage: Mileage is now 90,500 but will creep up as I still drive it sparingly. I bought it with 81,250 in November of last year so put on about 770 per month...
Color: TiKap
Transmission: GT
Condition: Great!
Option packages: Premium pkg, Climate pkg, boosters, backup sensors, factory subwoofer (makes a huge difference)
Location Columbus, Ohio
Selling Price $14,000, $16,000 with warranty (see warranty below).
Contact Information: you can PM me or reply to post with questions.
Modifications: None really, I have only added ipd’s poly upper engine stabilizer kit, billet transmission torque mount bushings and the resonator delete. the EBD was previously removed.
Accident history: None
Maintenance history: This was dealer maintained by the first owner, bought as a CPO and dealer maintained by the second owner, and I bought it and have done oil changes every 3 months (as required by my extended warranty).
Dealer Service from Previous Owner
12/30/09 – 48628
RR seat belt button replaced
1/26/10 – 49,733
Replace Steering Angle sensor/clockspring
Replaced terminal in Pin 4 of BCM
1/29/10 – 49,805
Replaced CEM
5/22/2010 – 54316
Replaced Evaporative lines cover
Left rear shock
ECM/TCM update
12/29/10 – 64,280
60K Dealer service with plugs/flushed all fluids/lubed doors/trans flush/air and pollen filter
Right rear shock
Angle gear reseal bevel gear resealed flange and crown ring replaced bleeder nipple
Reset and re-rivet lower front bumper facia
Replace torque bushing
Right front inner tie rod
10/6/12
New Battery
Work I have done since November 2012
12/15/12
Right CV axle
March 2013
Brembo front rotors
OEM Rear Rotors
Euro ceramic pads all around
IPD blue torque mount bushing
IPD poly engine bar inserts
June 2013
OEM front Struts
IPD HD spring seats
Bilstein strut mount
July 2013
E-brake shoes OEM
90,380 – 10/29/13
OEM spark plugs
lifetime alignment from Firestone, aligned 3 times (CV axle, changing from snows to summer, struts)
oil change every 3 months (per warranty requirements)
The warranty is through route 66 and has been good so far, I think there is a $50 transfer fee, but the car is covered for alot, here is my "should I get a warranty" post with details. It covers the car until 11/5/2016 or 129,275 miles. Not bad...
The Bad:
Honestly not much, all it has is stitching loose in the drivers bolster, not torn, just needs to be sewn, and I was planning on replacing the tires next spring, it has dunlop SP sport's on now and blizzaks for winter that have at least one more good season on them. It has a couple of light clear coat flecks peeling, I will try to get pics of it.
Here is what she looks like (cell phone pics so far, sorry). Had the engine detailed the outside and professionally claybared and sealed with Blackfire Wet Diamond paint sealant in August ($175), didn't know I'd be getting the company car...
It has been raining here so hopefully it will clear up this weekend and I can get some good pics outside
