1995 940 Starting Issues
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
mollymarlei
Year and Model: 1995 940
Post by mollymarlei »
I have a 1995 Volvo 940 that does not want to crank when the temperature outside is below 60 degrees. If it is above 60 she will crank and run fine. We have change the fuel pressure regulator, the coolant temp sensor, rpm sensor, cleaned the idle air control valve. We have spark and fuel it just seems we are not getting enough air. Any help would be greatly appreciated.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Have the throttle switch been verified to be closing when it is colder?
That has been a common issue with your symptoms listed. Things change dimensionally when they cool.
mollymarlei
Have not tried that.....thanks we will try that next. Is there any way to check to see if it is working properly?
