1996 850na What's hardest part of changing exhaust manifold?
This topic is in the MVS Volvo Repair Database » Aftermarket Headers - Significant Quality Differences
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
xHeart wrote:A side-by-side visual of two manifold for area around the flex...any comments?
DNA Motoring
Estonian variation
The first part is by far of better quality. It also seems to be in inox. It has very good welding.
The cuts on the second part look really poorly done which can be a good indicator of the general quality. The welding seem acceptable. It also seems to be regular steel going to rust everywhere. Even then, a cheap part might be worth if it lasts a few years, but this one looks so poorly manufactured, I won't buy it.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Good to know oragex.
I will update on how Estonian manifold performs, meanwhile, we know for certain our bigdaddylee is running on the DNA Motoring's manifold for few years without change of heart, I guess.
osman
Year and Model: 2002 c70 hardtop
Post by osman »
"The Estonian Variation" sounds like a chess opening gambit.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
xHeart
Post by xHeart »
osman wrote:"The Estonian Variation" sounds like a chess opening gambit.
Interesting take osman. The Latvian gambit is known.
burnout8488
Year and Model: 1999 S70 AWD
Post by burnout8488 »
Other than the EGR (Just delete it!), how is the fitment of the Estonian manifold as far as lining up with the exhaust pipe, and does the heat shield bolt on perfectly with no bending?
The only way I'll ever get an aftermarket manifold is if it is dimensionally identical to an OE part. If I have to stretch or stress the exhaust in any way to get it to bolt up, the manifold goes back. So I'm really interested in hearing someone's install experience as far as "bolt-on" fitment went.
I just realized that the EGR bung for you guys with older 850s is shared with the SAS system on later N/A 850s. I deleted the SAS on my gf's 850 using an M16x1.5 drain plug from Advance Auto parts, with a standard Volvo oil plug crush washer.
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
xHeart
Post by xHeart »
burnout8488 wrote: The only way I'll ever get an aftermarket manifold is if it is dimensionally identical to an OE part. If I have to stretch or stress the exhaust in any way to get it to bolt up, the manifold goes back. So I'm really interested in hearing someone's install experience as far as "bolt-on" fitment went.
There were plenty of clues in cn90 and bigdaddylee write up.
Removing two vacuum lines at EGR was the best clue, it made removal and installing of the EGR assembly easier, not effortless.
Use of bottle-jack to support CAT after the 4 nuts were off at the flange help lowering CAT just enough to pull-off manif, which was a hint for me to pre-screw the 4 studs fully at flexible flange while on the bench, loosely install at the head first and then raise CAT back for the flange studs to align and come through. It worked like docking with ISS.
Just an easy fitting exhaust manifold method, and excellent writeup with lotsa clues.
The bracket ears were bit off, it needed an upward push for the pre-heat plate holes to align and screwed down straight.
Now, I want to restore the original Volvo exhaust manifold at the Flex, put the weaved thingy back on, and find an alternate for the broken bracket. After a closer look, Volvo's manif appears welding free.
Planning on replacing the corroded exhaust pipe south of CAT. I would prefer Volvo's but nothing lasts on our slated roads. Starla is OEM - $100 less - a coat of high-temp paint may add few more years to Starla... or Walker.
xHeart
Post by xHeart »
A view from below two weeks after the install of Estonian Variation. It appeared wet so I ran my finger, the red arrow points to the skid of my finger. Is it normal, or does it need tightening?
Exhaust manifold - a view from below
plumsmooth
Year and Model: V70 Wagon 2004
Post by plumsmooth »
Hey it looks like this can be done from above!
Considering I replaced the PCV system maybe I can pull this one off too...
And considering I would be letting a muffler guy finish the rest with new Cat and Muffler I would still save a bit of $!
And avoid the hassle of a Mechanic messing something up -- up top?
Nevada1906
Year and Model: 1995 850 Turbo
Been thanked: 30 times
Post by Nevada1906 »
The hardest part of the job?
Wanting to do it.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
