Volvo Plugs
turbotim2
Year and Model:
Re: Volvo Plugs
Post by turbotim2 »
Thank you for all of the helpful replies. I ended up ordering the FR7DP's. Thanks again!
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
turbotim2
Year and Model:
Post by turbotim2 »
I changed the plugs yesterday on both the XC70 and S60. Be sure to gap your plugs! They were all way off. I had two (cylinders 2 & 3) that I thought I was going to break off while removing. I loosened them and then sprayed some PB blaster in there and let it sit while working on the others, that helped a lot. I also used a bit of high temp antisieze on the new ones so the next time should be easier. While double checking my owner's manual on the correct gap I noticed it recommended Champion plugs.
2004 XC70
