Power steering leak questions
AaronA
Year and Model: 2001 V70 2.4T
Post by AaronA »
Just opened the hood and noticed signs of leaking around my power steering pump. Sure enough, the reservoir was low and almost empty. I stopped at the local Autozone and bought some power steering fluid to top it off (which I'm now reading might not have been the right fluid).
Questions:
Does anyone have any experience with used P/S pumps? The new ones are $350 (IPD) or $280 (Groton - rebuilt), but the used ones go from $75 to $150. Money is a little tight now, so I was thinking of the used part, but I'm worried about grime or dirt that might be inside it screwing up the rack. Any thoughts?
What is the correct P/S fluid for a 2001 V70? Is it P/S fluid? Dexron III? ATF? Or some other synthetic? and do I now need to flush the system? Or can I just suck out the reservoir and put in the right fluid?
I need to do the PCV service (as soon as it warms up - car has 118k miles on it), so was hoping I could wait until then to replace the P/S pump, as it would be easier to just do them both at the same time. Is this a bad idea if I just keep filling the reservoir?
Thanks,
Aaron
otis44
Year and Model: 2006 S60 T5
Post by otis44 »
The correct fluid is:
http://www.fcpgroton.com/product-exec/p ... ory_id/146
Some Napa's carry it, also available at the Volvo dealer, but FCP is the best deal I have found on it. I can't say what is going to happen due to the wrong fluid being put in the system. Some have reported failure or poor performance due to incorrect fluid and another poster here recently stated they found a fluid made by Lucas they believed to be compatible and so far so good. I would get the correct fluid in the system as soon as possible if it were mine. You can get it out by placing the return hose in a can or bucket and let the pump empty the system.
As far as the pumps themselves I don't believe them to be a high failure item and I wouldn't have any problem with a used one as long as the car didn't have a ridiculous amount of miles that it came from. I would definitely be sure that it is the pump itself leaking and not a line or a faulty o-ring where the line attaches to the pump before I bought another.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
I would check the lower hose under PS resevoir AND THE CLAMP first
There is an updated clamp, most of the OEM clamps leak
Oil travels
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
At 108,000 mi on my '02 S60 N/A I located a PS fluid leak that is developing at the drive end of the pump (not so much of a leak, just some seepage). No noticeable change in fluid level either.
Is it time to order a replacement pump?
PS Pump 031212.pdf
PS Pump Leak
(602.9 KiB) Downloaded 305 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
regent wrote:At 108,000 mi on my '02 S60 N/A I located a PS fluid leak that is developing at the drive end of the pump (not so much of a leak, just some seepage). No noticeable change in fluid level either.
I won't worry about. Mine to it's doing this and it's been a while.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
If the seepage works its way into the control arm bushings there's some motivation for you however if you can manage the seepage with degreaser every oil change you should be OK.
I mention this because it happened to the 2002 S60 AWD I just sold however the leak was from the clamp on tbe PS reservoir.
swedish tank
Year and Model: 2004 XC70
Post by swedish tank »
The power steering hose on my XC70 that goes from the reservoir to the pump was leaking where it goes into the pump. The reservoir also had developed a leak where the two halves join. I ordered a new hose and reservoir and installed with regular worm gear hose clamps from the auto supply store. I couldn't justify $7 a hose clamp from the Volvo stealership. I will keep an eye for leaks, but can't imagine that there would be that much difference between hose clamps.
