1986 Volvo 240 DL Wagon
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Aldaar
Year and Model: 1986 Volvo 240DL
Post by Aldaar »
I can figure out most mechanical problems but the electrical ones kill me. And of course my problem electrical.
For starters, the 'fuel relay circuit' is dead. This I have proved as another forum suggested connecting fuses 4 and 6 - which does make the fuel pumps work. I have spark as I can drip a little gas into a vent in the intake air tube and the car will turn over. So I think the problem is with the fuel injection area.
However - just to note this, the car was starting sporadically and then not starting at all; could the fuel relay circuit also control the electrical part of the electro-mechanical fuel injection? The trick above links the pumps but does it also link something else?
There is something called the 'cold fuel injector' which I think is an electrical device; pump?
Any help very appreciated. I need to move!
SlowVO1
Year and Model: 85-240
Post by SlowVO1 »
I am having this same issue and cannot find any threads about it. could someone help me out with this? i have spark and fuel to the injectors, just no fuel into the cylinders.
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
SlowVO1 wrote:spark and fuel to the injectors
Pull off one injector clip, with ignition on, does one side have 12V?
93Regina
Post by 93Regina »
Btw, crank engine when checking for voltage
